bro share ko lang din...almost 1 year narin ako sa pagaaral ng photo shots..
share ko lang ha...
ok lang ba mga sir? 8) 8) 8)
here's mine sony alpha350
DSLR-A350 Features
* 14.2-megapixel APS CCD sensor with 14M/7.7M/3.5M image size choices
* Sony Alpha/Minolta-A bayonet lens mount
* Recording choice of JPEG, RAW, or RAW+JPEG
* Shoot at normal 3:2 or 16:9 (HDTV) aspect ratios
* Super SteadyShot anti-shake system with viewfinder indicator
* D-Range Optimizer for greater highlight and shadow detail
* Anti-dust system automatically shakes dust off the imager
* Large variable angle 2.7-inch TFT color Clear Photo LCD Plus screen
* Live View function allows you to use the LCD to frame your pictures
* Penta-Dach-mirror viewfinder with 95% coverage and Eye Start AF
* 9-point AF with Wide, Spot and Local Area Selection
* Eye-start Auto Focus, starts the focus process when you put your eye up to the viewfinder
* Shooting modes: Full-auto, Programmed AE with program shift, Aperture priority, Shutter priority, Manual and Scenes
* TTL metering: 40-segment honeycomb-pattern, Center-weighted or Spot
* White Balance: Auto, 8 presets and Manual color temperature
* Unlimited Continuous 2.5fps shooting Large/Fine JPEG images, up to 4 RAW or 3 RAW+JPEG
* Shutter speeds: 30 to 1/4,000 seconds, 1/160 sec. flash sync
* ISO Range: 100, 200, 400, 800, 1600, 3200 equivalent
* Built-in TTL popup flash with red-eye reduction (auto popup when using full Auto)
* Hot shoe for Sony/Minolta Program Flash units
* CompactFlash I/II card slot, Microdrive and MSDuo/MSDuo Pro compatible (with optional adapter)
* Video Out with selectable NTSC or PAL timing
* High capacity (1600 mAh) lithium-ion battery pack and charger included
* Exif Print, PRINT Image Matching III, PictBridge compatible
