mine 15/38, good performance, 55kg driver.. mahina lng pag my angkas.. depende sa timbang moHi guys im newbie here, is anyone here tried this combination? any feed will do thanks![]()
yeah i think weight has the factor..mine 15/38, good performance, 55kg driver.. mahina lng pag my angkas.. depende sa timbang mo
yah.. kung magaan kalang ok lang ganyang combi.. haha pag my angkas nga lang baba performanceyeah i think weight has the factor..![]()
is your MC is sniper MX?maganda pala combi ang 15/40 mga sirtry nyo po 75kg pala weight ko
hahaha tested kona sakin 15'/38, dun hiyang mc ko, tested kona sa dragtry 15/40 you wont regret it![]()
MX sir .. i just installed it yesterday 15/40 428 all sss brandis your MC is sniper MX?![]()
Tips: if you are still in experimenting stage you can just buy cheaper sprockets until you find the right sprocket combination then that's the time for SSS or other quality brands..MX sir .. i just installed it yesterday 15/40 428 all sss brand![]()
i see..what is your ts when using 15/40 sir?Tips: if you are still in experimenting stage you can just buy cheaper sprockets until you find the right sprocket combination then that's the time for SSS or other quality brands..
15/40 is lower than your stock sprocket ratio... if your weight is below 60kg then good for you.. else wasted money...![]()
haven't tried that combination... since my weight is 80kg, i use higher gear ratio"low speed" sprocket combination... IMO on 15/40 you need more than a kilometer to attain your top speed...i see..what is your ts when using 15/40 sir?
I tried 14/40 but i found it very hard to rev up in 1st gear but i can feel the power when reaching TS, :/haven't tried that combination... since my weight is 80kg, i use higher gear ratio"low speed" sprocket combination... IMO on 15/40 you need more than a kilometer to attain your top speed...
15/40 = 2.67 ang ratio paps its lower than the stock combination with ur weight 75kgs.. i dont think the 5th gear has power to pull yourself.MX sir .. i just installed it yesterday 15/40 428 all sss brand![]()
i see, the reason i use the 15/40 because of many smx riders in our group use it for their short and long rides. Ill test the 15/40 combi for incoming short ride this weekend. Ill post you guys what is my feed back15/40 = 2.67 ang ratio paps its lower than the stock combination with ur weight 75kgs.. i dont think the 5th gear has power to pull yourself.
even me im 75kgs with the stock sprocket combination cant feel the power of 5th gear. But now im on 14/42 and attain 100kph+ in just a second ; and planning to change to 14/41 later![]()
upi see, the reason i use the 15/40 because of many smx riders in our group use it for their short and long rides. Ill test the 15/40 combi for incoming short ride this weekend. Ill post you guys what is my feed back![]()
try 15/42 or 14/40...so what about in my case? i'm 65kg (145Ibs) what's the best sprocket combination for me? (all stock)
