Sprocket Combi for my R-edition
JhayBoo
wow .. that's very hard , what about 14/43 ?
hmmmm... try this one bro, this will help you a lot:
Goodtimes ride safe!
Heres a table of sprocket combination for reference.
the stock gear ratio is 2.6 (in bold)
the color green gear ratio are high speed sprocket combination.
the lower the gear ratio, the more high speed (top speed, less acceleration)
the color red are low speed sprocket combination.
the higher the gear ratio the more low speed. (good acceleration, less speed)
Front teeth | Rear teeth= Gear Ratio
16 34 = 2.125
15 32 = 2.13
16 35 = 2.19
15 33 = 2.20
16 36 = 2.25
15 34 = 2.26
14 32 = 2.28
16 37 = 2.31
15 35 = 2.33
14 33 = 2.35
16 38 = 2.38
15 36 = 2.4
14 34 = 2.42
16 39 = 2.44
15 37 = 2.47
16 40 = 2.5
14 35 = 2.5
15 38 = 2.53
16 41 = 2.56
14 36 = 2.57
15 39 = 2.6 Stock gear ratio
16 42 = 2.63
14 37 = 2.64
15 40 = 2.67
16 43 = 2.69
14 38 = 2.71
15 41 = 2.73
16 44 = 2.75
14 39 = 2.79
15 42 = 2.8
16 45 = 2.81
14 40 = 2.86
15 43 = 2.87
16 46 = 2.88
14 41 = 2.93
15 44 = 2.93
16 47 = 2.94
15 45 = 3
14 42 = 3
15 46 = 3.07
14 43 = 3.07
14 44 = 3.14
14 45 = 3.21
14 46 = 3.29
so if you want more top speed than stock settings
use 14t front and 36t rear
or 16t front and 41t rear
if you want more acceleration
use 13t front and 34t rear
or 16t front and 42t rear
BIGGER TIRES (100/80 and up): use color red
SMALLER TIRES (80/80 and below): use color green
http://www.yamahat135.com/threads/t135-sprocket-table-combination-part-ii.404/
phuc9867
16 34 = 2.125
15 32 = 2.13
16 35 = 2.19
15 33 = 2.20
16 36 = 2.25
15 34 = 2.26
14 32 = 2.28
16 37 = 2.31
15 35 = 2.33
14 33 = 2.35
16 38 = 2.38
15 36 = 2.4
14 34 = 2.42
16 39 = 2.44
15 37 = 2.47
16 40 = 2.5
14 35 = 2.5
15 38 = 2.53
16 41 = 2.56
14 36 = 2.57
16 42 = 2.63
14 37 = 2.64
15 40 = 2.67
16 43 = 2.69
14 38 = 2.71
15 41 = 2.73
16 44 = 2.75
14 39 = 2.79
15 42 = 2.8
16 45 = 2.81
14 40 = 2.86
15 43 = 2.87
16 46 = 2.88
14 41 = 2.93
15 44 = 2.93
16 47 = 2.94
15 45 = 3
14 42 = 3
15 46 = 3.07
14 43 = 3.07
14 44 = 3.14
14 45 = 3.21
14 46 = 3.29
Wow ,that's help a lot bro , my jupiter mx 5 speed has big rear tires 100 - 70 - 17 . I shall study this chart you gave me .
JhayBoo
np bro! anytime!!! just try to understand the foreign language......
just try to use GOOGLE TRANSLATOR if you are having difficulties understanding it... goodtimes!
ricky0822
got my sprocket combi 14/38, so far satisfied from 1st gear up to 4th gear... good acceleration and top end...:cool::cool::cool:
Samboy Del Rosario
if you cant find sniper sprocket. you can use RS sprocket. just tell the motorcycle shop sprock of RS.. so far im trying to experiment in different sprocket combi.. im using RS sprocket on my sniper mx i got 14,15,16 front sprocket and 34,36,38,42 rear sprocket so far 15/42 combi but i will try 14/41
Samboy Del Rosario
not sure. yun nga ata basta sprocket ng RS un lng sabi ko binigay nila match nman hehehehe
basta sabihin nyo lng po sprocket ng RS ibibigay na nila un.
ricky0822
try using 14t on your engine sprocket then maintain the 41t rear sprocket...;)
acceleration n topspeed bro
Mr. ice, is 14/41 combi are good for my stock engine? right now im using 14/38,, well!.. quite satisfied top end is soo good but bad acceleration... i travel from bulacan-makati and vice versa.. as you say 14/41 is good for top speed and acceleration? what about 15/40 i read more a lot for this combi.. and its hard to find :(:(:(
sagad
its not hard to find..just buy a RS100 40T rear sprocket..:cool:
SPEED RACER
14/38 combi bro is a good one for stock engine just tune your carbs to correct mixture
JhayBoo
check this out bro:
16 34 = 2.125
15 32 = 2.13
16 35 = 2.19
15 33 = 2.20
16 36 = 2.25
15 34 = 2.26
14 32 = 2.28
16 37 = 2.31
15 35 = 2.33
14 33 = 2.35
16 38 = 2.38
15 36 = 2.4
14 34 = 2.42
16 39 = 2.44
15 37 = 2.47
16 40 = 2.5
14 35 = 2.5
15 38 = 2.53
16 41 = 2.56
14 36 = 2.57
16 42 = 2.63
14 37 = 2.64
15 40 = 2.67
16 43 = 2.69
14 38 = 2.71
15 41 = 2.73
16 44 = 2.75
14 39 = 2.79
15 42 = 2.8
16 45 = 2.81
14 40 = 2.86
15 43 = 2.87
16 46 = 2.88
14 41 = 2.93
15 44 = 2.93
16 47 = 2.94
15 45 = 3
14 42 = 3
15 46 = 3.07
14 43 = 3.07
14 44 = 3.14
14 45 = 3.21
14 46 = 3.29
http://www.yamahat135.com/threads/t135-sprocket-combination-part-ii.404/
JhayBoo
check this out bro:
16 34 = 2.125
15 32 = 2.13
16 35 = 2.19
15 33 = 2.20
16 36 = 2.25
15 34 = 2.26
14 32 = 2.28
16 37 = 2.31
15 35 = 2.33
14 33 = 2.35
16 38 = 2.38
15 36 = 2.4
14 34 = 2.42
16 39 = 2.44
15 37 = 2.47
16 40 = 2.5
14 35 = 2.5
15 38 = 2.53
16 41 = 2.56
14 36 = 2.57
16 42 = 2.63
14 37 = 2.64
15 40 = 2.67
16 43 = 2.69
14 38 = 2.71
15 41 = 2.73
16 44 = 2.75
14 39 = 2.79
15 42 = 2.8
16 45 = 2.81
14 40 = 2.86
15 43 = 2.87
16 46 = 2.88
14 41 = 2.93
15 44 = 2.93
16 47 = 2.94
15 45 = 3
14 42 = 3
15 46 = 3.07
14 43 = 3.07
14 44 = 3.14
14 45 = 3.21
14 46 = 3.29
