Sprocket Combi for my R-edition
sugyanz
for stock set up and tires better used 15-40.. just add 1 teeth..for better acce and top... because if you used 15-42 u'll hit the limiter early..
L2 sprocket fits our t135 perfectly....41t is just so hard to find. hehehehe
ai oo nga brod..ang hirap hnapin ngsprocket nato................
chrisz
guys pa ot...i need your advice too,,my modes are Brt cdi,cms valve spring,s4evo cams, wat would u think the best sprocket combi. for my r edtion,,namban pipe for my exaust...thnx so much
sugyanz
go for 15-42 sir.. good acce and top end... kahit pa akyat pa lahat ng road na dadaanan mu..hinding hindi ka mabibitin...hehehe
Paladin
or try 14-39 for lighter handling.
chrisz
thnx bro...how bout 15/42???yung tropa ko kase naka 15/42 and yet sabi nya parang bitin kaya daw mag 15/43 daw ako???
sugyanz
15-42 fits perfectly of the modz u mentioned...i guess sa 43t parang maganda lang sa acce wla na sa top end...but u can try it..mura lang nman sprocket paps...desisyon mu parin masusunod..so better try both for u to feel the power of acce and top end...goodluck
chrisz
thnx men...
sugyanz
whewww...really ang laks nmn ng snipee mo paps to say na all stock?ako nga my mods na hirap abutin 120....ill try this combi thnx
big tires with stock magz work better on 15-42...it has top end also..big tires kasi kaya hindi tatama agad ang limiter...i was refering kasi sa set up..small tires kasi ako and rimset.hehehe
jiGGer
what's the best combination for my sniperMX? i'm using 80/80 front & 100/80 rear? all stock w/ stock pipe
WEIGHT MO PAPZ..
TRIED THESE COMBIS:
14-40
15-42
14-42
im about 65-70kgs..all stock po smx
these combis could reach 120..basta mahaba daan..
mas madali lang 120 sa 14 42 though..
mas may laman na yung 5th gear..
Johnny Tran
hmmmm... try this one bro, this will help you a lot:
Goodtimes ride safe!
Heres a table of sprocket combination for reference.
the stock gear ratio is 2.6 (in bold)
the color green gear ratio are high speed sprocket combination.
the lower the gear ratio, the more high speed (top speed, less acceleration)
the color red are low speed sprocket combination.
the higher the gear ratio the more low speed. (good acceleration, less speed)
Front teeth | Rear teeth= Gear Ratio
16 34 = 2.125
15 32 = 2.13
16 35 = 2.19
15 33 = 2.20
16 36 = 2.25
15 34 = 2.26
14 32 = 2.28
16 37 = 2.31
15 35 = 2.33
14 33 = 2.35
16 38 = 2.38
15 36 = 2.4
14 34 = 2.42
16 39 = 2.44
15 37 = 2.47
16 40 = 2.5
14 35 = 2.5
15 38 = 2.53
16 41 = 2.56
14 36 = 2.57
15 39 = 2.6 Stock gear ratio
16 42 = 2.63
14 37 = 2.64
15 40 = 2.67
16 43 = 2.69
14 38 = 2.71
15 41 = 2.73
16 44 = 2.75
14 39 = 2.79
15 42 = 2.8
16 45 = 2.81
14 40 = 2.86
15 43 = 2.87
16 46 = 2.88
14 41 = 2.93
15 44 = 2.93
16 47 = 2.94
15 45 = 3
14 42 = 3
15 46 = 3.07
14 43 = 3.07
14 44 = 3.14
14 45 = 3.21
14 46 = 3.29
so if you want more top speed than stock settings
use 14t front and 36t rear
or 16t front and 41t rear
if you want more acceleration
use 13t front and 34t rear
or 16t front and 42t rear
BIGGER TIRES (100/80 and up): use color red
SMALLER TIRES (80/80 and below): use color green
http://www.yamahat135.com/threads/t135-sprocket-combination-part-ii.404/
Based on this chart and the fact that my stock sprocket combo is 39/15 and my tires are bigger than stock, would an increase to just 40/15 be a noticeable change in acceleration? I'm looking to get a small advantage towards the acceleration side but not to lose too much on the top end. My bike reaches about 140 kmph right now so I have some to leeway.
sagad
based on my experience...there will be an increase in acceleration and you will get your topspeed quicker than stock sprocket combi.. :)
