Johnny Tran
So 41T from RS100 will fit on my bike?
41t on rs100 and L2 is so so hard to find bro....40 and 42 marami.hhehehehe
totoo...sumakit na ulo ko sa kakahanap...pero meron sss...kay boss jhay..btw, just tried the 42/15 and i lost too much on the top end... from before, 140kmph to 120kmph now.i'm really in need of a 41T 428 if anyone knows where i can get it, pls pls let me know! thanks.
140 km/h?? all stock?? cdi?? bore?? muffler?? wat is ur modification to reach 140 km/h??btw, just tried the 42/15 and i lost too much on the top end... from before, 140kmph to 120kmph now.
brt cdi, 62mm uma cyl. bore, stage 2 cams, 30mm carb with high compression, ahm exhaust, bt-39ss bridgestone tires (my speedometer has an inaccuracy of almost 20kmph so we measured against my friend's car's speedometer)140 km/h?? all stock?? cdi?? bore?? muffler?? wat is ur modification to reach 140 km/h??
pm boss_jhayi'm really in need of a 41T 428 if anyone knows where i can get it, pls pls let me know! thanks.
i thought ur motorcycle was all stock... hehe from all stock f i will change my cdi to brt dualband and vixion valve.. and longy pipe.. wat probably my top speed?? comments sir pls......brt cdi, 62mm uma cyl. bore, stage 2 cams, 30mm carb with high compression, ahm exhaust, bt-39ss bridgestone tires (my speedometer has an inaccuracy of almost 20kmph so we measured against my friend's car's speedometer)
i think the brt dualband is pretty good, just need some cams and valve springs, and the pipe is ok then you should be able to get to around 135kmph like i did before i changed to bigger bore. just be careful not to let it over rev (or overdrive) too much bc it will damage the piston like mine. safe riding bro!i thought ur motorcycle was all stock... hehe from all stock f i will change my cdi to brt dualband and vixion valve.. and longy pipe.. wat probably my top speed?? comments sir pls......
the rest all stock..
wow dangerous.. hehe wat kind of cdi is slightly powerful dan stock cdi and less powerfull dan rcdi's??i think the brt dualband is pretty good, just need some cams and valve springs, and the pipe is ok then you should be able to get to around 135kmph like i did before i changed to bigger bore. just be careful not to let it over rev (or overdrive) too much bc it will damage the piston like mine. safe riding bro!
pde din po png STXnot sure. yun nga ata basta sprocket ng RS un lng sabi ko binigay nila match nman hehehehe
basta sabihin nyo lng po sprocket ng RS ibibigay na nila un.
im selling muy rcdi KITTY xbox edition,,09261338602hayisttt!!! balik stock po muna ako 15/39 huhuhu... na try ko na halos lahat 14/38,15/40,15/41,15,42 ang problema lng stock cdi ko... ngaw ngaw ng ngawngaw... eeennnnggg...engggngeeenggg.. need ko racing cdi wala pa pambili ehh!![]()
sir ano na po mods ng engine mo? tire size? at ano po ang pinaka okay sa lahat ng combi na na try mo? TIA.........hayisttt!!! balik stock po muna ako 15/39 huhuhu... na try ko na halos lahat 14/38,15/40,15/41,15,42 ang problema lng stock cdi ko... ngaw ngaw ng ngawngaw... eeennnnggg...engggngeeenggg.. need ko racing cdi wala pa pambili ehh!![]()
