You can buy it too... if my memory serves me right when you buy RB rear disc convertion kit it is included, however some shop dont include this and they sell it seperately....this type of hub is what ive been looking for.. hope you can help me.. thanks..
When i bought my 5 spokes rb no hub also..my friend advise me to use the crypton hub since that what he used also with his rb mags...swak na swak po xa...i bought the crypton hub for 100+..thank you sir for the advice but when i bought the rims, they did not offer me the hub.. ill ask them again if they could supply the hub..
I will post some pics later for your reference bro..thanks idol shin.. ill look for a crypton hub today and try it on my sniper.. thanks also master rich.. if the crypton hub will fail ill ask the vendor of the mags to supply me the hub.. ill let you know the developments.. thanks to t135!
Michelin 100/80TS sorry for the OT...@shinshan03...what is the brand and size of that rear tire? Tnx
Bro, hows the centre allignment of the rim and swingarm? Mine is more to the right side of the swingarm.. Not centre at all.. Really need help
Need to place some washers bro...I place 1 washer which is the thick one. In case you the thin washers you can just add them..Bro, hows the centre allignment of the rim and swingarm? Mine is more to the right side of the swingarm.. Not centre at all.. Really need help
You had the washers at the rear brake side or the sprocket side?Need to place some washers bro...I place 1 washer which is the thick one. In case you the thin washers you can just add them..
Yes.. I place inside the swing so that it would not be noticeable.You had the washers at the rear brake side or the sprocket side?
I understand its inside the swingarm, but is it at the rear brake side or the sprocket side?Yes.. I place inside the swing so that it would not be noticeable.
