Stock Bore With Cms Cams Stg.2(to Pocket Or Not?)
albert_manio
Ask your trusted mechanic bro. AFAIK you need to valve pocket your piston when using higher lift cams. I'm using cms cam bro with valve pocketed piston.:)
Sir hows the performance of cms cam? Im planning to buy soon. Tia
chie
sir chie.. what do you choose between uma hi lift and cms cam hi lift? suggestion sir
better use CMS bro different in duration. negra cam is just like a stock cam but different with the duration and also you dont need pocket if negra cam. for me if you load engine LOAD it! with power not a little bit power:thumbsup:
suplado010
i recommend not to add gasket because its useless and danger to your engine:D just pocket it by 2mm if not it will stock up! and your valve will bend :(
and also re-jet your stock carb with 110mj:thumbsup:
it is also safe but the compression will decrease because you add more room to your chamber...it is only for people who dont want to pocket their piston..
chie
do not trust gasket believe me some of modes failed because they use base gasket to compensate space but time comes to fitted that and its become thin so the result BOOOM! and also leak of oil result to become wear your crank. what gasket you used bro if alloy that safe.
for someone don't want to pocket your piston try stage 1 cam much better than you use cms but some base gasket in your black. :)
ride safe!
  • Like
Reactions: ash
rich_havens
agree with sir chie... if you want power then get the full potential if you have enough resources...
