Stock Fuel Gauge
Jval Zkie
Hi! Guys, I found out this morning that my fuel gauge is not working when i refuel full tank. The gauge is not rising to the top level. Someone knows how to troubleshoot this or do i need to buy a new fuel gauge. My bike is 2 years & 1 month old.
4kasridersclub_ph
up for this guys pls help
EinVer
try to check the wires beneath your fuel gauge, there will be 3 wires there, black, brown, and blue-green. check for loose connections.
another connection to check for is the socket on your gas tank. try to disconnect it and spray some wd40.
if you have a friend with t135, you could link the wires from your fuel gauge to his, so you could confirm if its the problem or not.
the way i imagine your problem, your fuel gauge probably needs replacing, but its just my speculation :)
the_one
maybe the gasoline boy accidentally detached the socket on your gas tank. i experience this before.. :D
Jval Zkie
@Einver
I think i need to replace it. banaklas ko from the tank para makita yung loob. ayun yung contact nya pudpud na. na experience ko na to before sa shogun pro. I need to buy a replacement for it. Saan kaya maka bili?
@the_one
Thanks sa input.
mingomz
My fuel guage is stuck in the middle. One of my electrician told me it was shorted...
Even if I gased up full.
What can I do? I plugged in a different speedo and the needle went to full.
thanks
Jval Zkie
better check your panel display. look my other thread at Philippines sniperx1r i already posted there how to fix this problem.
Jval Zkie
yup! i already fixed it. if i read your post thoroughly at goffs thread been done it earlier hehehe... it's the disconnected resistor (the big one) i re soldered it. my problem is how to remove the needle indicators. im afraid i might destroyed them by pulling out it hard. what i do is slightly tilt the dashboard so i can have access on the resistor. all ends well my problem is solve.
here's the link:
http://www.yamahat135.com/forum/viewtopic.php?t=3240
mingomz
Thanks sir,
You gave me an idea. head surgery ngaun snipee ko. hay.. ill check the panel din later.
aey
Hey guys the problem with my gauge is that it always indicates a full tank until it only has about a liter of gasoline in the tank.. Then the indicator will go down quickly as if it only gauge a liter of gasoline.. Is there a way to make it work the way it supposed to be?..
the_one
check this part..
13 5YP–F4500–00 FUEL COCK ASSY 1
chie
up for this thread
- problem of gauge if not going to "F" sign this is the problem
just want to share.:)
