Stock Pipe On Vixion Bore
Paladin
Safe but the stock pipe is small for vixion bore. Like for example of FZ16 with stock pipe, stock pipe worked with it but the power is not there much. Epistaxis!
Mafiaflix
No problem for stock exhaust pipe but you need change it's header to bigger for optimum result, and don't forget to rejetting your carburetor.
jiGGer
thanks brothers...its ok if i'd be sacrificing its full potential..
than sacrificing money or license with the "smurfs";);):D
sniper135lc
how's the performance with these modified stock pipes?
not sure about the performance because didn't used one of those modified by jad racing. but according to the feedback of my co-riders its just like your on a free flow pipe i mean open pipe.
xniper03
i thought its the elbow only that was modified:)
sir i have a sniper mx stock pipe with kalkal pipe by jad racing, its not that loud like real open pipe,, it sounds like a v8 power pipe.. smooth but powerfull.. jad racing is trusted on kalkal pipe.. if you want you can swap your stock pipe to my kalkal pipe to test yuor vixion set... look for the forum FOR SALE... you will see my kalkal pipe.. the tread said SWAP... just text me at 09167483121
Paladin
Difference on performance with kalkal pipe is not that much. Just like using a power pipe with silencer on it.
Paladin
what do you mean sir?
Meaning to say when you remove the divisions inside the canister of stock pipe to make it kalkal. It increases the air flow to give more power on the bile. However, the diference is not that much because the pipe diameter is just the same.
