sir how much it cost you for the radiator cover? how do you know if it is the original..tiaPafs if you no financial issue then this is no problem. Just avoid the engine for the meantime since its still new. External modification just like one of the forumer here. RB end bar, Lever, Front shock, big disk, swing arm, HID projector with angel and demons eyes, rearset. There is another forumer here who convert from SMX body to X1R body. So many options as long as sky is the limit. For me the only added thing i do is install radiator cover, RB fork stabilizer, RB bar ends, Handle grip and Lever. I'm still eye-ing for engine cover, chain tension-er, Those famous thailand seat and RB break plate. So it means what you really want and how much your capacity for modding?
copy that! ride safe sir!350 pafs including installation. I don't have any idea if there is original or not. but it will serve its purpose.to protect your radiator from foreign object..
front shock?..does it mean that it needs more support for endurance like the old model..old ones easily damage oil seal(if im rayt) & leakagePafs if you no financial issue then this is no problem. Just avoid the engine for the meantime since its still new. External modification just like one of the forumer here. RB end bar, Lever, Front shock, big disk, swing arm, HID projector with angel and demons eyes, rearset. There is another forumer here who convert from SMX body to X1R body. So many options as long as sky is the limit. For me the only added thing i do is install radiator cover, RB fork stabilizer, RB bar ends, Handle grip and Lever. I'm still eye-ing for engine cover, chain tension-er, Those famous thailand seat and RB break plate. So it means what you really want and how much your capacity for modding?
x1r body kit should be the best! if your planning to change your magz please pm or text/call me 09083573291..SUGGESTIONS PLZ...
nag drill lang ako ng new hole katabi ng stock na holes dun sa kinakabitan ng peg..no need na palakihin yung butas ng ehe...mas matibay pa....you like ako na magkabit bro...dito lng ako sa bacoor cavite...
is this true?widetire 360 at the back..what??nice bike.
yup edit lang.ang bagal cguro takbo nyan?.whats new w ur mx?pipes?rb?undernt?camsss?valvespring?rcdi?carbs?mukhang edit lang..
