vindeath07
bigger tires (heavier than stock + inaccurate odo)
hi job nay news on how to get the 26T gear 4???traxxas check out this 4th gear combination.. its a 23T (stock)/26T. this will give you a higher topspeed. maybe you can get hold of the 26T maingear??
TOTOO PO BANG ANG ALL STOCK NA SNIPER135 e HINDI PAPALO NG 135 HANGGANG 120-125 lang?
sv na e..thx dude ^_^
my old sniper (about 5 month old) can attain 110 - 120km/h at stock sprocket bt you must b leaning forward lyk a racer... hehehe.. all stock no modification even muffler... i'm 75 kgs. body weighti have 14/38 sprocket combination on my sniper mx but it can attain only 105-108kmh reading on my speedo. I try 15/42 and it runs till 110-115kmh. I'm about 85kgs, stock sprocket for me is not the best combi for attaining top speed unless you have modified your engine.
does the cdi of mio has a fan plug in?? will this later cdi match with sniper carb ??the best combination is stock setup mine is sock combination and my
1st gear 0-55
2nd 55-85
3rd 85-118
4th 118-140
take note only cdi was replace, cdi of yamaha
mio...
here is what www.gearingcommander.com says comparing the 4speed sniper vs 5speed sniper:Is it true that classic sniper has more top end speed than sniper mx even if it only has 4th gear and 22mm carb compared to sniper mx 5th gear with 25mm carb?
thanks papz.. i wish der was a cdi that has a limiter at 10,000 rpm.. i will buy that cdi hehe. our stock stock cdi can only rev up to 8500rpm ryt?? 1,500rpm differencial..
try 15/42 sirsir, whats the best sprocket set for 100/80 rear and 80/80 front in stock engine.
