T135 Sprocket Table Combination Part 2
dark_sniper_15
dude_pare01 said:
agree with traxxas here...
should also consider engine power when changing sprockets
a too low ratio for top speed might get too low for the engine power to drive the bike.. so all you get in 4th gear is deceleration instead of going faster...
as in my experience...15/40 is faster than 15/39 on our engine...coz with the 15/40...its decreases the engine load on 4th gear,and utilizes more of its power...but still,just like with scooters using roller weights...one combination for one bike may not work for other bike of the same model...its up to the owner to find out whats the best combination for his bike,patience is all you need
can anyone tell me where to buy here in the philippines a 40t sprocket, i am here in tondo manila.
if someone is willing to sell me 40t sprocket for my t135, just let me know the price.
BOMBIE
dark_sniper_15 said:
[quote="dude_pare01":3oj17n4y]agree with traxxas here...
if someone is willing to sell me 40t sprocket for my t135, just let me know the price.[/quote:3oj17n4y]
40T sprocket bro is i think not hard to find.., just ask for Yamaha RS100 sprocket... with your tire combination, 15/40 sprocket is appropriate.., just like mine.... I like 16/42 with my stock tire.
phl6684
15-39 as same as stock work 4 my weight n tyre..
dreaming of changing 13-33..with smaller tyre..it does have pickup n top..
4kasridersclub_ph
sir traxx help?my front tire is 80/80 and my rear is 90/80 is 15-40 suitable 4me?my engine is stock my max speed w/ 15-39 is only 115kph will 15-40 make it faster maybe just a little bit?
bro 4kas
40/15=2.66gear ratio
thats way too low speed bro.
check the next low speed to 2.6 gear ratio sprocket combi table
in the first post
use that sprocket combi and try...
sprocket size??
im using stock sprocket,80/90 front rear tyres..
max speed 120 only..full throttle..
what sprocket size shold i use 4 more t.speed??
plzz..somebody help me..thnx..
unlimited express
I tried 15/42. the result was better acceleration but lower top speed. you can feel the engine is at the limit but your slower than before. got back to the stock size.
yes bro thats because 15/42 is way too LOW speed on stock tire.
42/15 = 2.8
that means you need to pedal your bicycle 2.8times to make i full wheel turn, Unlike the stock gear ratio where you need to pedal only 2.6times to make 1 full wheel revolution
bro try these two combinations
16 41 = 2.56
16 42 = 2.63
that combination is the most nearest possible combi from stock.
then tell us which one works best
unlimited express
I dont know, but I used 15/42 with 80/80F and 100/80R and my speed somehow decreased in the end. you can feel that your engine is reving too much but the bike is slightly slower than stock.
SniperR135
like i posted before, i have great performance with my 16/42, my tires is 90/80f 100/80r. so with big tires this is ok bro
Zal_boyX
hye...
setup 16-42 .... 16 can fix to our standard motorbike? or need to modified?....
because i'm only know until 15....
BOMBIE
Zal_boyX said:
hye...
yes bro, it fits... I've used that setup before with my stock tire size...
SniperR135
i have the 428H DID chain which is really big. i didn't think it was going to fit with the 16 tooth, but it did with just a little room left to spare.
