i think sprockets of stx and dt 125 will fit
am using 15-36 sprocket with 80/80 front, 100/80 rear the accelaration is low but the speed is awesome!!!15-36..maybe bad aight???....u guys think???
stock engine stock pipeam using 15-36 sprocket with 80/80 front, 100/80 rear the accelaration is low but the speed is awesome!!!
the 1st and 2nd gear is short..but the 3rd and 4th gear for classic sniper is long..sir how's the performance of this sprocket combi, i'm using the same tire size right now... thanks in advance
same fitting with our bike? what sprocket combi r u using? 16/42 ?im using 16t of DT 125 sir
thanks bro.. at least now i already have an idea how to get 16t engine sprocket.. hehe how's the performance of 16/42 combi bro?it's what the saleslady say when i purchased the sprocket and it fits.. if your are still in doubt better bring a sample of our sprocket before buying just to make sure..
yes im back to 16-42 from 15-39 sprocket combi
oh its similar to the 15x45 that i used right now, the 2nd gear plays around 50 to 60 but when i shift to the 3rd gear it would be easy for it to reach the 100 kph.. or more, and yet I'm still confuse with my speedometer.. i feel that the speed of 90 it seems that the bike is running at 100 kph already... do you think thats possible?the 1st and 2nd gear is short..but the 3rd and 4th gear for classic sniper is long..
possible sir..better use gps for accurate speed..oh its similar to the 15x45 that i used right now, the 2nd gear plays around 50 to 60 but when i shift to the 3rd gear it would be easy for it to reach the 100 kph.. or more, and yet I'm still confuse with my speedometer.. i feel that the speed of 90 it seems that the bike is running at 100 kph already... do you think thats possible?
how do you use this kojack..?computer calculated sprocket combination 80/90 rear wheel, 112 chain link at 8800rpm for 4 speed semi auto yamaha t135
these are computer generated calculation for sprocket table on stock t135 4 speed 1st edition. we'll be able to get a rough idea on the top speed we are trying to achieve.how do you use this kojack..?
i am very much agree to you sir humanbasic. the chart shows for our reference only as per experience. i use 14.42, 15.42.. but it doesnt satisfied me. other thing the sprocket combi of other my have another result on you.16-43 with 70/90 tyres.if i'm using 90/80F and 110/80R,i will go with 16-46/45.by using smaller tyres,i can easily get top in about 400-500m if not mistaken.(140 kmh around 120 car speed) can also reach 160 kmh(130-140).actually,using bigger tyre on rear give u a feeling of 'heavy and umphh'...haha.but to save me cost,i go to smaller tyre.because using big tyre,u need to pass a point before u get the momentum,if u go under power,u can't feel the power,thus required more fuel in acc...
u can see my comments in sprocket combination for big tyre,and one big advantage,ur chain is more durable and noiseless.u knew that our chain easily turn noisy.
if ur weight is around 60-70 kg,u can try 16-39.i have tried this spec,can reach top to 170kmh,but lose some bit on acc.i luv acc,thus sacrified some top end.
study ur self interest,ur road,style of riding...u can get the best.do not set ur bike for other satisfaction,be yours.just sharing with u,no offense or show off intention.
correct me if i'm wrong.![]()
am using 80/80 front tire 90/80 rear.. what combination of sprocket can you suggest? i used 15x45 as of now.these are computer generated calculation for sprocket table on stock t135 4 speed 1st edition. we'll be able to get a rough idea on the top speed we are trying to achieve.
currently i'm using rear sprocket 37/ front sprocket 15, base on the table calculation above i could probably reach 128kmh +- wind, steep hill & mc condition
* another example if i were to use 36/15, the top speed on the sprocket table is around 132kmh
check out http://www.gearingcommander.com/
@audioguy on my stock t135 (4 speed) i'm using 37/15 = ratio 2.46, so on 45/15 = ratio 3.00... (assuming that you're also on the 4 speed version)am using 80/80 front tire 90/80 rear.. what combination of sprocket can you suggest? i used 15x45 as of now.![]()
let say:am using 80/80 front tire 90/80 rear.. what combination of sprocket can you suggest? i used 15x45 as of now.![]()
