audioguy
thanks for the info guys
it depends bro...but the mj115 pj22 is one of example of setup.160 is reachable but ensure that u use a light quality 4t oil
is it advisable for 59mm borekit bro?it depends bro...but the mj115 pj22 is one of example of setup.160 is reachable but ensure that u use a light quality 4t oil
applicable...but after the setup,ensure u recheck the plug,should be brownish to blacky....purpose to ensure that ur bike wont be jammed on heavy running.u can alsois it advisable for 59mm borekit bro?
from your current sprocket 14/40 you can try these and compare there differenceSir traxxas im using 80-90 front 100 - 80 rear (stock engine) but nob1 tribold pipe only, i preper to use SSS 14 /40, is it ok to use this combi on a stock engine? how is it effect? or is there any changes of performance?
or what is the best combi for stock engine except the stock sprockets? TIA
Continuation from part I
Heres a table of sprocket combination for reference.
the stock gear ratio is 2.6 (in bold)
the color green gear ratio are high speed sprocket combination.
the lower the gear ratio, the more high speed (top speed, less acceleration)
the color red are low speed sprocket combination.
the higher the gear ratio the more low speed. (good acceleration, less speed)
Front teeth | Rear teeth= Gear Ratio
16 34 = 2.125
15 32 = 2.13
16 35 = 2.19
15 33 = 2.20
16 36 = 2.25
15 34 = 2.26
14 32 = 2.28
16 37 = 2.31
15 35 = 2.33
14 33 = 2.35
16 38 = 2.38
15 36 = 2.4
14 34 = 2.42
16 39 = 2.44
15 37 = 2.47
16 40 = 2.5
14 35 = 2.5
15 38 = 2.53
16 41 = 2.56
14 36 = 2.57
15 39 = 2.6 Stock gear ratio
16 42 = 2.63
14 37 = 2.64
15 40 = 2.67
16 43 = 2.69
14 38 = 2.71
15 41 = 2.73
16 44 = 2.75
14 39 = 2.79
15 42 = 2.8
16 45 = 2.81
14 40 = 2.86
15 43 = 2.87
16 46 = 2.88
14 41 = 2.93
15 44 = 2.93
16 47 = 2.94
15 45 = 3
14 42 = 3
15 46 = 3.07
14 43 = 3.07
14 44 = 3.14
14 45 = 3.21
14 46 = 3.29
so if you want more top speed than stock settings
use 14t front and 36t rear
or 16t front and 41t rear
if you want more acceleration
use 13t front and 34t rear
or 16t front and 42t rear
BIGGER TIRES (100/80 and up): use color red
SMALLER TIRES (80/80 and below): use color green
16 34 = 2.125
15 32 = 2.13
16 35 = 2.19
15 33 = 2.20
16 36 = 2.25
15 34 = 2.26
14 32 = 2.28
16 37 = 2.31
15 35 = 2.33
14 33 = 2.35
16 38 = 2.38
15 36 = 2.4
14 34 = 2.42
16 39 = 2.44
15 37 = 2.47
16 40 = 2.5
14 35 = 2.5
15 38 = 2.53
16 41 = 2.56
14 36 = 2.57
16 42 = 2.63
14 37 = 2.64
15 40 = 2.67
16 43 = 2.69
14 38 = 2.71
15 41 = 2.73
16 44 = 2.75
14 39 = 2.79
15 42 = 2.8
16 45 = 2.81
14 40 = 2.86
15 43 = 2.87
16 46 = 2.88
14 41 = 2.93
15 44 = 2.93
16 47 = 2.94
15 45 = 3
14 42 = 3
15 46 = 3.07
14 43 = 3.07
14 44 = 3.14
14 45 = 3.21
14 46 = 3.29
13 39 = 3sir ano ratio pag 13*39???? TIA
sure po yan sir??13 39 = 3
tnx bossKuha ka calculator. Idivide mo. Mkukuha mo gear ratio. Kng d ka sure compute ka ibang sprocket combination.
patpata bro,, kaw adino?? baka agam amu ta pay???Wlang anuman sir. San ka banda dta candon bro?
ahh wen amamok da rocky bosssan fdo la union. Gayyem ko jay tropa candon, da lyndon, kuya javier, rocky,harvy, jurry etc. Ken jay tga santa maria ni jaymar. Kadwak nga agrirides isuda.
rinabii da agtambay jay tambayan daahh wen amamok da rocky boss
geh sir,,,, set mo sir??ok.. Pkikmusta nlng. Tnx. Ride safe.
