Amp meter can test your battery if you have one, better yet go to Battery shopelyouch said:sir try charging the battery also you have the option to replace the battery solution, as you said it is 1yr old already and check the battery condition using a tester. so you will know if the battery is working properly.mingomz said:Q: Do i have to replace my stock battery if I have the ff installed in my sniper?
- HID (all weather)
- Bosch horns (r-type)
- Racing CDI (just incase lang)
Kaya ko lang naman natanung kasi lately, pumipitik ung ilaw sa sa guage ko pag nagsisignal ako. Nagdidim sya pag nakasignal ako. Pero nakapatay ung motor nun. pag naka on di naman.
(wala pa ako cdi)
Battery is one year old
Parati ko naman namaimaintain sa water -- always on the marker.
sori newbie lang sa mga ganitong situations.
TY
you can never rely on a Multi tester cause it only reads the Voltage not the Ampere...what important is the Ampere reading, Voltage will surely reach it marks but not always the ampere
hope this helps
ride safe
