@Linjun, my snipee is still down...No time to have it fixed...possible resolution is to have someone to go here at my place and have it fixed.
getting tired of it already...tsk tsk tsk
ah i see.. but do you already have the parts that you needed ? i have already put back my kick starter... powder coated it in black courtesy of yoko, i seldom used my electric starter now ..problem is ..kicking it is just like kicking a brick wall (grabe ang tigas) oh cams...marcusfilter said:@Linjun, my snipee is still down...No time to have it fixed...possible resolution is to have someone to go here at my place and have it fixed.
:lol:pototoy316 said:drink plenty of milk it helps prevents osteoporosis, and it will make the BONES on your knee much stronger![]()
nakasubok ka na ba ng kick start ng naka racing cam stage 2 plus something he he he cge papasubok ko sayo sa eb he he hepototoy316 said:drink plenty of milk it helps prevents osteoporosis, and it will make the BONES on your knee much stronger![]()
Tol, pwede ka naming pasyalan sa place mo if you think we can help.marcusfilter said:@Linjun, my snipee is still down...No time to have it fixed...possible resolution is to have someone to go here at my place and have it fixed.
Tol, try to look for a starter for bikes with a much higher engine displacement. See if you can use it on your bike by means of the electric starter.linjunvelasco said:nakasubok ka na ba ng kick start ng naka racing cam stage 2 plus something he he he cge papasubok ko sayo sa eb he he hepototoy316 said:drink plenty of milk it helps prevents osteoporosis, and it will make the BONES on your knee much stronger![]()
wow so nice of you...really appreciate it...the problem is even if we find out what's wrong, the second problem is the parts needed....wingman44 said:Tol, pwede ka naming pasyalan sa place mo if you think we can help.marcusfilter said:@Linjun, my snipee is still down...No time to have it fixed...possible resolution is to have someone to go here at my place and have it fixed.
Pwede ko namang isama tao ko, if ever.
ha ha ha...just imagine, when you start it using a kick start you will feel the compression, then it bounces really fast...if you're not lucky, it will hit your leg and you will have a "mekeni Tocino"ha ha halinjunvelasco said:nakasubok ka na ba ng kick start ng naka racing cam stage 2 plus something he he he cge papasubok ko sayo sa eb he he hepototoy316 said:drink plenty of milk it helps prevents osteoporosis, and it will make the BONES on your knee much stronger![]()
hahahaha we can swap snipee if you like, so that i can test you monter bike :lol: :lol: :lol: :lol: :lol: :lol:linjunvelasco said:nakasubok ka na ba ng kick start ng naka racing cam stage 2 plus something he he he cge papasubok ko sayo sa eb he he hepototoy316 said:drink plenty of milk it helps prevents osteoporosis, and it will make the BONES on your knee much stronger![]()
There is a bolt holding the footrest on your rear set. Put a thin lock washer before you tighten the bolt to prevent it from loosening.hugaw said:tanong lang po mga papa
nakaX1r RS po ako...
& ung rider footrest
is lumuluwag, so wat
i did is everytime may
lakad ako, i check it
always...
anu po pwd gawin para
po talagang secured
xa always?...ung d xa
lumuluwag?....
how are ? when did you arrive? hows bicol? anyway dont worry if your bike reaches only 100kph you still drives fast than most of us he he he ..its the driver not the bike he he heroadtrip047 said:need help....... im not feel good enough with the performance of my 2 snipee. reach only with the maximum speed of 100 kph. what will we to this?
100kph top speed for a sniper?roadtrip047 said:need help....... im not feel good enough with the performance of my 2 snipee. reach only with the maximum speed of 100 kph. what will we to this?
pres sa fastlanemarcusfilter said:@Jason, good idea...ha ha ha
@Linjun, where can you buy the said starter assembly?
