bandido
AFAIK tps error code is different from the thermal sensor code. Mine is still blinking the same 1long 5short codes even if the tps is connected or not. and to simply diagnose this problem whether if its the tps or the thermo sensor is to simply unplug the tps and the thermo sensor and you'll see that the 1st code will be different from the second code. I'm not totally sure but AFAIR the thermo sensor will be 2long and 2 or 3 or 4short codes. until now my tps is remain disconnected from its socket and i still don't have any idea how much will it cost me to replace it from 3s.
