the best carb for t135
icemanx1r6
superturbocompound said:
a keihin 28 fcr would be the best i think.this model of carb is supplied to most high performance bikes pre efi.
yoshimura tmr-mjn28 will be the best carb and it is proven and tested <<
nkamri
i hav TZM carb that oready being port and polish.. what i've done to my bike was:-
1) custom modi stock exhaust to bigger manifold, straight pipe
2) aftermarket cdi from BRT
3) bigger fuel inlet (from carb to block)
4) #130 mainjet (stock carb)
5) and planned to put bigger block (maybe 60mm) and performance cam.
the question is: how to install this Yamaha TZM carb into the bike, is there any performance part to connect this carb to the engine block such as bigger/different/custom carburetor neck.. and one more things bcoz this is 2-stroke carb and dont have TPS, is there any problem using carb that dont have TPS?
phl6684
u just buy aftermarket uma racing neck..specially to install 2 stroke carb to our bike n as long as 4 stroke..n for the tps..u just make a shortcut to ur fan..coz the tps is no use anymore when u installed 2 stroke carb..peace..hope that help..
n more thing bro..is ur engine is stock??y u put #130 mainjet??just curious..
the TPS works just like a volume controller in your radio.
it turns clockwise when you increase throttle
and turn counter clockwise when you release the throttle.
you just have to find a way to turn the TPS
as you increase the throttle.
The TPS connector does not have anything to do with the fan.
Fan and TPS are different connectors.
TPS is for ignition timing,
Fan is with the thermosensor.
most who go into bigbore disregard tps
but TPS is really the eyes of the engine
without TPS it just cannot give the best potential of our engine.
if youve noticed, High performance bike like motogp bikes
and motocross bikes have TPS on it.
search for specs of latest motocross bikes and bigbikes.
TPS is the eye of the engine to see whats outside.
upgrade your carb and find a way to move that tps sync with your throttle.
ofcourse make sure your cdi supports tps 100%, i mean 3D ignition timings.
Mafiaflix
I just use Kawasaki KX 100 PWK Carb. with some little mod from Thole one of the best engine moddificator from my town in Yogyakarta.
The result is totally different, lower fuel consumtion, wider powerband or extra horsepower, more torque at lower Rpm.
In 169 cc engine It just need Pilotjet 38 and 110 Mainjet.
Azzurri
as i know the smallest diameter TMR-MJN carb that has TPS is 32mm..huhu bydway, our stock is VM type, and yoshi is TM type...does anyone know their diffrences?
LoggY
:) hi all..new member here,just want to ask what is the difference between UMA n TZM carb.which one is nicer and more powerful?
