the modification of my 4year old lc135
jimpie
bro suggestion lang gear 4th lang palitan mo para sa top end? wag yung buong transmission gear? gastos lang pero hindi ganda performance? change your carbs for better acceleration, for safe purpose for your 60mm bore kit para hindi madali masira yung piston mo sa init. ride safe bro....
tnx. sa tip papa speed :)
macoolet
sorry di ko naidugtong,yup mahahabol talaga sa sprocket pero yung stress sa makina is lesser kung retain yung stock 4th gear..just same din yung sa sprocket na 14/42 and 15/45...yup the same ratio of 3.00 pero for me i will prefer 15/45 for touring,then pang araw araw naman yung 14/42..i think naexplain na ni traxxas to dati...
bro when changing 4th gear you must chance also your sprocket combi,ako bro naka 4th gear ako 15/39 sprocket combi gamit ko, wala ako masabi sa performance good top end.
macoolet
uu paps 2 yung CMS na nakita ko,isa ke sir job dun sa excel nya and isa dun sa site ng cms pero mgkaiba sila ng gear ratio,pati sa 4th,20 yta yung ke sir job 21 yung dun sa site ng CMS,and also yung 1st and 2nd,meron pa din yung faito..waaa nagliliparan naman mga sniper jan.PERO IDOL KO TALAGA YUNG KE ROWN HAHAHA NAKAKAILANG BESES NA KO NG NUOD SA VIDEO NYA WALANG KASAWASAWA.wala ako question sa top speed paps,ang point ko lang is yung stress na nabibigay sa engine and economical wise using stock tranny,sa daan jan sa inyo na hindi makita dulo,kahit stock tranny dudulo at dudulo naman din di ba,so pwede sa sprocket na lang galawin lalo yung ayaw magpabiyak ng makina at nagtitipid parang ako ..same din halos di ba yung top end,yun nga lang iba talaga pag naka 21t,kuha kagad top ng 4th gear,if ever,me tumakbo ng 160kph na sabay,yung isa on 11k rpm ung isa on 10k rpm,alin pipiliin...
20t yung kay job na cms 1,2,4 gear set ang faito may 1,2,4 na 21t yung 4th.
21t na 4th gear tested on rowan 180kph bisyo kit..jval15 165kph on stock bore. nonoy philip 165kph stock bore. bam 165kph stock bore. kuya frank 165 kph on stock bore.
ebidenxa yan kng ano performance ng 21t na 4th gear.
sprocket combi nila 15/39
macoolet
tsaka paps in a few years ,iba na mods ng sniper jan sa inyo,pagalingan na ng parachute para huminto motor :D
macoolet
eto masarap...primera at segunda pa lang ulam na hahahah..ang napansin ko lang paps,halos lahat ng labas ng tranny,stock 3rd gear din same ratio,wala kaya lumabas na mas hispeed ng konti sa 3rd gear?kasi pansin ko halos lahat idinidikit yung gap sa 3rd gear,1st and 2nd closing to 3rd,then 4th closing to 3rd,what if a different approach,staying stock 4th,then 3rd closing to 4th and so the 1st and 2nd.then tsaka maghabol dun sa low speed sprockets.
4th 21t /2nd 29t /1st 32t
faito gear set
SPEED RACER
bro this kind of sprocket combi your using is for low speed, i use this combi before 15/42 when i not yet install 4th gear, after i install 4th gear i go back to stock sprocket combi..
SPEED RACER
1. high speed sprocket combination ( less rpm high top speed )
2. low speed sprocket combination ( high rpm less top speed ) galit engine mo
bro if you use stock gear go for low speed combi, if you change to racing gear like 4th 21teeth go for high speed combi, like 15/39 ( hindi galit yung engine sa ganitong combi bro ).
macoolet
paps sample ko lang yan :( with same ratio mas madali kasi compute 3 lang e hahaha..pero gamit ko is 15/44 or 42 kasi wide tires ako 90/80 front and rear
SPEED RACER
15/42 = 2.8 gear ratio
15/44 = 2.93 gear ratio this two combi is better for stock 4th gear.
if you change 4th gear to 21t then you use this sprocket 15/42 or 44 ( wala talaga dulo bro, galit yung engine mo)
macoolet
yup pero kung magrimset ako and 60/80 tires pwede ako sa 15/40 or 39 kasi magaang na itakbo..kaya lang hindi palagay loob ko sa manipis na gulong :(
