The Power Of Stock Bore
Stockbore
Stock cdi
Stock cams
Vixion valve spring
28mm keihin
15x39 sprocket
Squished band stock bore
Racing clutch plate
Racing Clutch spring
20 teeth 4th gear
Racing ignition coil
Head Not ported nor polished yet
Front - 80/80
Rear - 90/80
top speed -------- 130kph rev limit (normal position).
jangbest
Stock cdi
Stock cams
Vixion valve spring
28mm keihin
15x39 sprocket
Racing clutch plate
20 teeth 4th gear
Front - 80/80
Rear - 90/80
What if PnP na ang head ...
What will be the performance ????
Stockbore
i haven't really tried that one sir. i tried pnp before but with a racing cam. stock head vs pnp head, for me i really dont feel the difference since im not a dragster. they seem both the same if you are just playing on the road
SaM03
but did u notice sir the accleration of your mc with the PnP head? =)
Stockbore
how much it cost for your set sir??
Vixion valve spring - 1.5k
28mm keihin - 2.8k
Squished band stock bore - 1.8k (@kimredbull blockworks)
Racing clutch plate - TDR 1.6k
Racing Clutch spring - LHK 600
20 teeth 4th gear - YYPANG 3.5k
Racing ignition coil - UMA 900
=12,700 sir
Stockbore
My point here sir is that blockworks is really effective. im really surprised that my speed reached 130kph faster than I expected. I tried before with a stock standard block with brt racing cdi and the speed can only reach 120kph. I'm just happy to tell you that blockworks really work. plus its our stock bore so its better and safer.
SaM03
can u share what u did on your block sir? ;)
joman
what do you mean with squished band stock bore?and stockbore where you from?im planning to send some parts of my engine to kimred,but im from bicol its too far...
Stockbore
squished band meaning shaving your block sir to increase compresion. Im from cagayan valley. Near Aparri. Better if you send to sir kimredbull for precise squish banding
casmot
squish band/shave block generates much more heat due to much higher comp, its better to do this upgrade on a high end material such as diasil or chromebore
