[TIPS] How to set your TPS
valentino_rossmann said:
Hi Frozen Fire,
How to loosen the TPS nut? Which one is the TPS nut? Do u have a picture of it? I'm confused....
thanks..
the tps nut is the screw which attaches the tps to the carb.
you need a screw driver to loosen and adjust the angle.
sorry, been busy for months :D
I've set my own TPS and found that the color code is right.
The nut is right what traxxas said
sniper71
Well I don't know whether the values below will work in other countries version... but let's try
Tools:
- Digital avometer
- Needle
To check your TPS:
1. Turn off your engine and electricity, release TPS wires from the socket.
2. Set digital avo to ohm meter, connect (+) terminal to blue wire and (-) to black-blue wire.
3. Check whether the avo shows value between 3k-7k ohm, if not, it's time to replace your TPS with the new one
To check your TPS linearity:
1. Plug back in TPS wires to its socket. turn on electricity.
2. Set digital avo to dc voltmeter, connect (+) terminal to yellow wire and (-) to black-blue wire.
3. Check whether the avo shows value 5V, if not, it's time to replace your TPS with the new one
4. Set digital avo back to ohm meter, and open throttle smoothly.
5. Check whether the avo shows linear increase value from 0-5k ohm, if not, replace your TPS
To adjust TPS degree:
1. Set idle rpm to 1300-1500 rpm
2. Set digital avo to dc voltmeter, connect (+) to yellow, (-) to black-blue wire
3. Adjust your TPS position by loosen its nut to get avo value between 0.63-0.73V
Bad/broken tps will cause your engine to get bad mileage and bad acceleration. Too low idle rpm will cause engine to sound unpleasant because decompression is still working.
Sorry if there are some bad english :D
bro,if i adjust TPS clockwise (sagad) the reading is .6v..then when it adjust counter clockwise..it reads 1.3v..what is the best adjustment pra sa snipee ntin bro?...(nosebleed,..hehehe)
JoyT
Hi guys... How bout adjusting TPS for Jupiter MX (5speed) ? Itz impossible to set unless u remove the carb,coz the TPS,is directly behind the main (left,clutch side)frame,unlike Sniper,Lc (4speed) .. Any 1 tried adjusting the TPS? :(
z_ride13
Sir Sniper71, do you mean when the TPS is adjusted downwards (counter clockwise / downwards) the volt reading is up to 1.3 volts and it lowers when adjusted clock wise (clockwise / upwards) to .6 V? so, to increase the volts reading is to turn the TPS piece downwards?! TIA
sniper71
bro adjust ur tps while in idle speed and feel d differnt between counter ang clockwise,..my set up is clockwise..mganda sunog ng spark plug ko..color brown..
sniper71
z_ride13
I've tried to apply all your inputs last night on how to check and correct TPS setting, right degrees and proper volt output..and i feel so much difference when i ride my bike today..
I just observed that when i push the TPS assembly downwards the volt output goes up..and when upwards it decreases in volt output.God speed Sir Sniper71 and all who started this thread..cheers!:coffee:
kojack
Very Nice!:thumbsup: is the step below is what you did to get the volt output goes up.. gonna try this ASAP.. :D
z_ride13
Yup,i just insert a pin or a needle on the top of the wires.. yellow (+) and black blue (-). then test its connectivity from the inside of the socket to the pins i insert. then start the engine, adjust the accelerator cable by loosening its metal nut thread just below accelerator throttle grip to get the right RPM . then I connect the Voltmeter/Tester set to DC 2.5 volts to get the right reading .63 - .73v by adjusting downwards to increase or upwards to decrease output.
kojack
Thanks @z_ride13 for the confirmation, the yellow (+) and black blue (-) wires on idle, adjusting the TPS position downwards to increase or upwards to decrease output to get the right reading 0.63 - 0.73v ;)
z_ride13
i have a busted park light when i have set it beyond .73 i don't know if this is still connected to TPS settings..can anyone confirm this..
utoyjeren
i tried this on my sniper ac i push the TPS upward to its fullest and the bike response better, but in my x1r it seems no effect at all i don't know if the TPS was worn out because there's no tester/digital avometer available that i can use on :rolleyes:
kojack
i've adjusted the TPS degree manually. on idle turn the throttle 1/4, turn the the TPS clockwise until i hear the revving changes. the mc respond much better on the road but no higher end gain. will adjust the TPS again when i have the multimeter to get the proper volt reading... :thumbsup::coffee::sleepy:
john-locke
3. Check whether the avo shows value 5V, if not, it's time to replace your TPS with the new one .
question about this 5V . if i have 4.8 v maximum , need to replace it ???
