Tips Nmn Po For Mods. My Snipee?
chrisz
guys pa help nmn po sa pag mods ng bike ko?everday use ko poo sya pero gusto ko sana maging malakas at the same time ok parin kahit everyday used...e2 napo ang mga napalitan ko..
:namban pipe
:Rcdi dualband brt
:faito clucth spring zero
:faito switf-z lining
anu pa po kaya dapt ko idagdag jan at sana po maging compatible laht ng parts...balakas ko din sana itry mag bore-up kit?plss need advice tnx,...:)
turbulence
start with camshaft bro, yan na lang kulang ang bigger carb. maging halimaw yan. maging 155kph top speed mu niyan kahit stock bore ka lang
sa cams dami maganda... vixion cams, faito cams, regrind cams from camprofile then sa carb kahit 28mm lang na branded carbs pwede na... then pagmagRCDI ka palit ka na din ng racing coil...
chrisz
thnx bro i got my faito s4-evo cams + cms Valve spring...my idea ka ba how mch kiehin 28mm at racing coil at kung san ako makaka bili????thnx
sa fb paps at sa forsale section natin dami jan... :D
kumpletohin mo na paps, high tension wire, racing coil, iridium spark plug... :D full mod ka na lang ung gear ng mc mo palitan mo... :D
guitarizta
trr
thnx to this thread papz
no prob paps... just a word of caution in buying online, make a background check muna sa taong nagbebenta or better yet go for the trusted sellers here in T135. Mahirap na kasi dami scammers ngayon...
tama bro, bro mgkanu b pamember ng life plan, 4got q ask sau s samal eh, busy kasi...
txt me bro 09497288979 para maoffer ko sayo ang pinaka need mo na life plan kesa bibigay ako sayo ng mga life plan na di suited for you...
im covered by a Philamlife Life Insurance plan Vanguard100 with natural death life coverage of 150K and another 150k for ACCIDENT... so if ever may mangyari sakin at least kampante na ako sa naiwan ko...this product also have a 1k DAILY HOSPITAL INCOME, meaning whenever i got to be admitted to a hospital ive got to recieve a 1k/day compensation from philamlife...
and i got this plan for 13k/year in 5 years...
chrisz
asko ko lang po mga sir bakit parang di gaano nagbago yung top speed ko eh ang dami ko napo napalita .... e2 po mods ko
Rcdi - brt dualband
faito S4evo cams
Faito clucth spring ZEro
Faito clucth lining
Cms valve spring
irridium spark plug
kagabi kase try ko sa edsa going to cubao ok ung 1st gear at 2nd gear pero yung 3rd gear parng pakat sa 100kph tapos 4th gear parang wala na hatak?sa sprocket combination po kaya my problem?stock pa po kase sprocket ko?plss help baka meron kau suggestion thnx po!
vhadz
ok bro copy,, ill call u as soon maayos cp q, minsan lng aq online this days mejo bz kasi, u know na its chirstmass,,ride safe
towendz
Rcdi - brt dualband
faito S4evo cams
Faito clucth lining
Cms valve spring
irridium spark plug
IMO lang pafs Sprocket po cguro, try mo 15/42 para my arangkada at dulo
aklan
ganyan din nga ung sakin eh nka faito s4 mtrt vspring saka brt dual
hirap ko palagpasin ng 115 sabi nla pagna ganong mods kaya na lumagpas ng 125.
