Sige ba... One reason why we opt to go for R150 valves is because the stem is short, meaning we can go for supeeer hi-lift cams without worrying kung mag uuntugan yung In at Ex, kung sakali man pwede parin natin bawasan ang diameter ng valves provided na hindi aabutin yung pag uupuan ng valve seats (parang Mio Cam 3 modification style, paki research nalang po guys)... 2nd, pag nasira, its easy to get a hold of, walang problema sa supply unless you want non-magnetic valves (Precision pwede pasadya or order sa Indo)... Yung paglalagay ng 220 shim, I have to give it to Bong, siya ang nag share nito although I did it before using different size ng shim kaso di ko naperfect so I used 220... Totornohin lang yung retainers (Hi Speed style) para di tumalon... Pinaka advantage nito is walang limit sa Cam na gagamitin... May mga taga Pampanga dito na ganito ang set dati ewan ko lang ngayon kung buhay pa yung set up kasi alam ko naibenta na ata...thopiang said:mga masters paki enlighten naman po sa mods ng head, re: raider valves
ilabas na ang dapat ilabsas hehehe
sir x-project, share more on this topic
thanks
Maiksi ang stem ng R150... Using shim will resolve this issue bro... And yung Valve Cotters (lock) is stock, pwede sa Sniper valves pwede sa R150 valves no worries...thopiang said:papa jeff, isang tanung lang at am ready to this mod:
may modifications pa ba dun sa valves ng raider, kailangan pa ba bawasan yung haba? sakto lang ba yung canal para sa lock?
share mo lang kung me gagalawin dun sa raider valves and the rest kami na bahala
salamat
ano pa?X Project said:Sige ba... One reason why we opt to go for R150 valves is because the stem is short, meaning we can go for supeeer hi-lift cams without worrying kung mag uuntugan yung In at Ex, kung sakali man pwede parin natin bawasan ang diameter ng valves provided na hindi aabutin yung pag uupuan ng valve seats (parang Mio Cam 3 modification style, paki research nalang po guys)... 2nd, pag nasira, its easy to get a hold of, walang problema sa supply unless you want non-magnetic valves (Precision pwede pasadya or order sa Indo)... Yung paglalagay ng 220 shim, I have to give it to Bong, siya ang nag share nito although I did it before using different size ng shim kaso di ko naperfect so I used 220... Totornohin lang yung retainers (Hi Speed style) para di tumalon... Pinaka advantage nito is walang limit sa Cam na gagamitin... May mga taga Pampanga dito na ganito ang set dati ewan ko lang ngayon kung buhay pa yung set up kasi alam ko naibenta na ata...thopiang said:mga masters paki enlighten naman po sa mods ng head, re: raider valves
thanks
Ano pa po?
Shim 220 ang gagamitin bro... Yung inuupuan ng Valve Cotters di ba maliit yun kaya pasok siya sa loob tapos may mas malaking bilog pa bago yung surface ng Valve Cotter sa itaas... Yung mas malaking bilog yung totornohin para umupo ng maayos yung shim... Iipitin yun ng tapet screw kaya hindi siya tatalon pero dapat 0/0 clearance wag lang tutulak sa valves para umangat sa seat or skin dati .005 (stock is .0010 In at .0014 Ex) straight In/Ex... Gets ba bro or malabo yung explanation ko?traxxas-modifier said:di ko ma gets ang shim, guys please enlighten me
eto ang shims ng raider diba?
RAIDER VALVES HEAD
paano yan malalagay sa sniper paps? after ng valve cotter lock is wala nang nag hohold,
mismo yung screw valve adjuster na lang, right?
ano mag hohold ng shim?
thanks sa answers
also anong size ng valves ng raider?
salamats sa tips papa xproject and jefraider
Pwede, mapapa-ubra pero hanap ka mahabang tapet screw or sagad mo sa baba yung tapet pero sirain bro... Napupudpod yung valve tip at hindi consistent ang taoet adjustment palagi dahil lumulubog yung valve tip at umiigkas so hindi sentro ang tulak ng rocker arm sa valves kasi tinatamaan yung retainers eh... Shim is the best talaga... Simple lang naman yun, di ba makapal yung shim 220? totornohin lang yung retainers para makapason ng husto yung shim, yun lang ok na yun...thopiang said:ahhhh naguguluhan lang ako dun sa shims, di ko magets hehehe
bka puede gawan ng diagram, sir admin patulong hehehehehe
sir x-project, puede ba hindi na lagyan ng shims?
