top speed of your Sniper R-Edition?
rodds_16
what is the highest/fastest speed you attain on your R-edition?road condition, your weight, tire size,sprocket combi and fuel you used?..with engine mods or stock engine?..thanks for sharing.
the_one
dpat paps maka120kph yan.. ala nman nagbgo s technologu ng T135 eh bukod s 5clutch lining..
rodds_16
ako na mauna mga paps sa akin 3 moths old,3k+ odo reading stock engine..before stock pipe ako kaya almost 100kph on 3rd gear but on 4th gear konti lng dinagdag nasa 100+ lng kahit anong piga ko ganun prin ayaw na tumaas pa ng speed ko mahaba ung daan..185lbs ako stock tire..nung nag open pipe ako ganun parin konti lng dinagdag masmadali mka 100 sa 3rd gear,4th gear walng power sa madaling salita..
yanski
ako stock engine naka pipe lang caltex gold gas 15 42 428 sprocket 80/80 and 90/80 mizzle tire 240lbs 110+ kaprasong lampas sa 110 mark sa long stretch
the_one
sagarin mo ung 3rd gear paabutin mo s before d limit or 90kph pra kahit pano umabot ng mga 110-115kph.. unti lng tlga increase ng 3rd to 4th ng T135..
rodds_16
the_one said:
[quote="rodds_16":rb5slxdl]ako na mauna mga paps sa akin 3 moths old,3k+ odo reading stock engine..before stock pipe ako kaya almost 100kph on 3rd gear but on 4th gear konti lng dinagdag nasa 100+ lng kahit anong piga ko ganun prin ayaw na tumaas pa ng speed ko mahaba ung daan..185lbs ako stock tire..nung nag open pipe ako ganun parin konti lng dinagdag masmadali mka 100 sa 3rd gear,4th gear walng power sa madaling salita..
sagarin mo ung 3rd gear paabutin mo s before d limit or 90kph pra kahit pano umabot ng mga 110-115kph.. unti lng tlga increase ng 3rd to 4th ng T135..[/quote:rb5slxdl]
ahh ibig sabihin sa 3rd gear 90kph then shift to 4th gear na ganun po ba?
rodds_16
caltex gold din gamit ko all stock maliban sa nob1 pipe.
the_one
rodds_16 said:
[quote="the_one":1wb7c8v5][quote="rodds_16":1wb7c8v5]ako na mauna mga paps sa akin 3 moths old,3k+ odo reading stock engine..before stock pipe ako kaya almost 100kph on 3rd gear but on 4th gear konti lng dinagdag nasa 100+ lng kahit anong piga ko ganun prin ayaw na tumaas pa ng speed ko mahaba ung daan..185lbs ako stock tire..nung nag open pipe ako ganun parin konti lng dinagdag masmadali mka 100 sa 3rd gear,4th gear walng power sa madaling salita..
sagarin mo ung 3rd gear paabutin mo s before d limit or 90kph pra kahit pano umabot ng mga 110-115kph.. unti lng tlga increase ng 3rd to 4th ng T135..[/quote:1wb7c8v5]
ahh ibig sabihin sa 3rd gear 90kph then shift to 4th gear na ganun po ba?[/quote:1wb7c8v5]
wag k matakot sagarin paps ndi sasabog yang motor mo kc stock p lahat yan at may limiter. try mo mag 90kph ang 3rd gear ska k magchange ng 4th gear mo. pero check mo rin kung may ibibigay p 3rd gear mo hala larga lng paps.. :twisted:
rodds_16
kaya nga mag90kph sa 3rd gear aabot pa nga ng 100 kso pag nagshift nako sa 4th bahagya nalang ang dagdag nya konti lng lampas sa 100 sa speed o' meter hindi nga makaabot sa 110kph..
yanski
HGM pipe ko for me naka dagdag siya i know kase ilang buwan ko nagamit motor ko ng stock pipe bago ko nag hgm. may nadagdag talaga sa power
jchris1124
115-120 ok na un,baka mamaya may magpost ng 130 ha?hehehe kahit medyo modified na 120 ok na un mas mabilis lang nrreach ang topspeed pag basic mod lang ginagawa
if all stock,
change rear sprocket to 41t or 42t
para masagad mo ang 9200rpm limiter ng cdi.
which will translate into more speed.
dont worry hinde sasababog ang makina,
mine 4th gear reaches 11,000rpm at around 140kph
so go revup your engine!!! :D
BasTarD
yan talaga prob mga daddy pag hindi digital speedo...haaaaays...kagabi nga, nag 100 na speedo ko tapos yung kasama kong vega nasa huli, sabi nya 100 plus na takbo niya...haaaays..
sorry ts...ot calling isdaniel...hehehe
cAtzkie
yung akin pumapalo ng 120 sa long stretch, gusto nya mahabang mahaba bago nya makuha yung 120, pro 110 yakang yaka nya.
stock engine lang sya, ecs garage open pipe, 15/42 sprocket combi, 90/80 front, 100/80 rear tire, 110lbs ako.
