TOPSPEED of your T135??
Januar
Wow!Lakas nmn ng motmot nyo...mine all stock, i'v tried at estimated 1 kilometres long straight run w/ back ride 125 kph..but when i got my leovince pipe the limiter activated at 120 kph on a 500-600 meters straight run..nka sibak na ako raider 150 twice dito sa amin all stock pa c snipee ko nun. we both all stock that time almost a 1 km run..and now im planning to install rcdi brt dual band,brt rcam stage 1 and valve spring..don't know the brand yet still looking for the good one...
Any advice to all the masters out there?thanks in advance...;o)...hope this simple mod can increase my speed of my snipee..
Ride safe guyz...
ok paps. para matapos na usapan.
lol ang usapan basta 140 takbuhin.. pag gauge mosa kargado yan kahit 130 lang takbuhin inyo tsak talo ko sa acceleration diba? 100% talo ko kasi iiwan mo agad ako ng malayo, gamitin nyo motor ko long straight , basta kasing bigat ko lang driver, basta atleast 140kph takbuhin mc ko.. well problem lang dyan is wala tayo cam for proof.. DEAL?
sige ganito nalang, tutal malapit ka lang naman samin. kilala kita Tolong. i gauge natin motor mo sa tropa ko, tutal hindi pa naman nakatono un, declare ko na set ng motor nya ha. 59 jvt, 28 mm na uma, down head, hi speed valves spring, crg clutch spring, may hint na, 130 lang top nun, pag natalo mo un, ung sakin naman,. hint din ung garda ng sakin, halos parehas lang ng sa kanya, pero sigurado ako, tulin ng SToCk na motor mo dun. bakit kase sa raider ka nag depende na takbo. malay ba namin na 120 lang takbo nun sabihin na 137 na.bukas na bukas set natin.dami pa naman na wanabee satin.
bat kilala moko brad haha.. ehh di kilala mo din si moge? sa kanya mo itanong, cya kasi yung raider na nilusutan ko, 137 daw takbo nya, pag alis tatay ko pwede mo test motor ko, baka sabihin mo mayabang ako, isa pa no ba mapapala ko magyabang ako dito, kaya ko lang post dito para malamang kung my other stock sniper na katulad ng performance na sakin
mhektheone
yan yan .. Malalaman na natin...
JapSpeed
oo nga magkakaalamanan na nga basta gamitin nya motor, long stretch , basta atleast takbuhin motor ko 140, di pwede i drag sa setup at sure talo akin sa arangkada
paps stock pa ba front tire mo? if stock size pa, cguro ikaw na ang my pinaka matulin na stock Sniper sa buong Pilipinas... IMO... ridesafe...
albertwen12
kasi pare for what i know . diba usually top speed ng sniper 120kph, akin 145kph, dapat mag iba man lang andar kung galaw makina, saka ang tipid sa gas motor ko, nasa subic kami umuwi kami sa gapan, kalahati pa gas ko.. if ever man setup to eh ang galing naman nung mekaniko kasi wala nagbago sa andar, and take note paps stock cdi to pero try ko baklasin flerings mamaya para makita cdi just to be sure.. kaya yung mga raider 150 na kasama ko shock hahaha.. and nga pala stock carb to..
80/80 tire
15-38 sprocket combi
stock carb
stock cdi, (sinilip ko lang sa gilid)
55kg driver
naka valve springs na siguro sir galing sa first owner. ridesafee--
kim19
to ts
di mo na kilangan ng makipagkarere at gumamit ng video cam.
cp with gps lang need mo mura lang yon,puede naman na manghiram ka lang.
marerecord na nito ang top speed mo.
maliit pa pala ang gulong mo sa unahan mataas talaga ang speedometer reading nyan.
ESOJ de GUZMAN JR
bakit kya bsta speed na pinag uusapan mhrap ng paniwalaan.. kasi almost or 98% ang member dito sa yt135.com ay owner ng sniper either classic at mx. madali lng sbhin ang topspeed either 140km/h pa yan doubt ang karamihan lalo na pg sinabi pang stock samantalang ung nagbabasa ay kargado ang mc. the best na gwin have some proof install a digital gauge dapat accurate ult ung rpm sa speed gaya ng naipost sa fb 9k rpm takbo ng mc nya 174km/h at gaya dto mdming batikos ult. bsta pg topspeed ang pinag uusapan with proof dapat. have a safe ride mga guys always wear a helmet.. ang motor my pyesa ang tao wala.. good day.
ESOJ de GUZMAN JR
kung stock sniper classic yan, imposibleng aabot ng 145kph kahit si barrack obama pa nag break-in nyan... maliban lang 2 km downhill... talagang my inborn na malakas na mc pero d aabot ng wamforty, kung lalagpas sa 140 yan palagay ko nakashave block nyan... or my kunting kalikot dyan, at saka stock sniper classic, hindi matalo ng stock raider wamfifty sa arangkada sa 200m... natalo ka kc naka 38T rear sproc mo...
hahah.. sir mac puso mo. mainit ang panahon baka maheat stroke ka nyan. hahah
oo tama ka dyan.. pero kasi stock nmn carb akin, matipid nmn sa gas, yung andar ng engine parang yung andar ng dati ko naging mga sniper, pang 3 na sniper kona kasi to, yung nagdare na si rhoitol pag pumayag cya na pumunta dito at test niya mc ko kung takbo talaga ng 140kph, if ever cya nalang magpatunay, di na kasi cya response dito eh, saka mas mainam kung my saksi kasi pagnapatunayan kong ganun top speed ko sasabihin nmn setup na engine
to ts
cge tol ganyan nlng, video ko sa una na gagamit ako gps, mas mabagal sa gps diba? gano dapat takbuhin kosa gps ?next weak my lakad uli kami ng grupo namin, 100km ride, matest uli top speed, ang pinag compare ko kasi pare speed yung takbo na raider na nilusutan ko, 137kph daw nung raider sagad na..
JapSpeed
if stock pa lahat ang tires at sprocket ng raider 150 na naunahan mo... then okay, mabilis nga snipee mo... kasi miron dng +10 sa speedo ng raider if ma palitan na ng sprocket at tires e.. not sure kng anong set ng sproket or tire size... ;)
kim19
gps ang basihan ko ng top speed.
sniper ko 130kph topspeed ko.garmin gps sa roman super hi-way sa bataan.
stock bro yung sprocket pare.. yung rear gulong 80/80
