Oh no!!!! its bad ....
you need to change your stock valve spring, to Racing Valve spring , and the same time change your Stock cams to RCams, to increase power
or else you will expresience valve floa, our stock valve spring can hold only upto 9200RPM, changing to R valve spring increase your
RPM upto 1200,
This is the logic :
Stock CDI , stock valve spring good stock set up .... Limiter on stock CDI protect our engine on each gear to avoid over rev.
Stock CDI, to racing valve spring no effect, Because stock CDI has limiter
Racing CDI, stock Valve spring bad, Increase RPM RCDI are no limiter
Bring back your stock CDI before its too late
andre install again your RCDI if you have Rvalve spring and rcams, to increase your power
AFAIK
