TOPSPEED of your T135??
ryann
sir just change your
Share your secrets please.. :rolleyes:
My sniper MX's top speed I think is around 115kph..
I'm 72kg in weight.. 15-44 Sprocket combi, Keihin PE27, CDI, open pipe and the rest stock..:D
Is it bad or not?:(
try to return your stock rear sprocket sir, and you will see the difference.
bhek_21
Thanks sir @ryann!:) Actually I'm already eyeing on it.. but I don't have 14t engine sprocket anymore, I gave it to my friend.. What I have here is 15T engine sprocket.. But I will use my 42T Rear sprocket (MK)... hehehe
ryann
sir if u use your 14 and 44 it lose more speed, and it will gain acceleration, u should just compare your 44 and 42 or your stock 39. regarding speed,
utoyjeren
i remember my yamaha x1r run 140kph when she was on stock tire with 4N big bullet pipe and high flow filter that was only once, but now my top speed is more or less 135kph with mizzle tl 80/80 f 90/80 r, nob1 neo silent pipe 15/40 combi, perhaps the speedometer of x1r is advanced of ( -+10 kph) to sniper, btw my bike mile age is going 14k maybe its time to replace the clutch spring and lining and add some basic mods calling sir speed maniac :D
sprinter777
front tyres 90/80-17: @ 150kph
stock displacement 135 cc
rcdi
rvalve spring
spec v cam (5500 to 11000 powerband)
stock carb
yypang pipe
ported /polished head
13-39 sprocket with 90/80 rear tyres..:)
Kim G Linagatik
new output hehehe top 180kph or more on 350m
Bore = 60mm
Stroke =64mm
Sprocket = 37t/15t
Tiresize F=70/80 R= 80/80
Stock Cdi
Cms camshaft
Single draw back i cant fully throttle my bike on everyday riding its really easy to damage the liner and piston replaced my block and piston for 3x already.
Looking forward for a bigvalve pm me up guys with some cheap bigvalve heads, i cant mve on till i have a bigger gapacity head
