TOPSPEED of your T135??
joman
130kph in 600-700 meters
racing cam
pnp head
cms valve spring
gearings 1,2,4th
hgm pipe
rear 80/80 front 70/80
15x39
astridnoelle
120kph on my 4-year old x1r. 80/80 front & 90/80 rear Mizzle taranis. All else stock except engine oil, unleaded gas, spark plug & brake pads hehehe... fair enough? i wish i cud do some mods but i"m kinda nervous...
120KPH Sniper MX All stock except tires: FDR 80/80 front 90/80 rear @7500 RPM. I still have to test the true topseed based on odometer (using UMA and GPS).
Break In: Using motomans hard break in
SaM03
me from 110kph it improve to 120kph current set.up Faito Lowcam Advance, Pitsbike Racing Cdi, MTRT Valve Spring, Faito Lighten Valves (Stock Size), YYPang Clutch Spring, Shave Bore 0.5mm all gasket attach, Spoke Rims, 70/90 tires front and rear 14/36 Sprocket Combi, Port and Polish (Only Exhaust), Stock Bore Stock Stroke =)
noi
my snippy can go 155kmh
on stock bore stock stroke
250 psi compression
stage 2 lhk cam retard 2 deg.
stock carb bt rejet 105 mj
80/80 rear tire 70/80 frnt tire
jad racing pipe +45 kls rider
vixion valve spring titanium valve
brt powermax dualband cdi
38t x 14t drive gear nd driven gear
250 psi compression
Bro where did you get the compression test? I'd like to have that. :D
