TOPSPEED of your T135??
cHozen One
jus want to share the tops speed of tamee..
from stock i reach 130kph
combi 15x42
and now with engine modes
150kph vixion bore up with recipe and a little bit magic of my mechanic
combi 15x44 pandigma!
happy . ..:D
Ericson
how come that my sniper AC is so damn slow.. im using MX mags.. all stock 120 is so hard on 15x39, and in 15x42 just 115.. :confused::confused::confused::confused:
ianghol
yes sir unfortunately its true.. maybe i should buy another bike like manager mac do with a higher cc displacement sir?
in stock primary gear ratio,
stock 1st and 2nd gear ratio
and stock secondary drive ratio,
you need to rev your sneeppeee 15500rpm
to max your 2nd gear at exactly 120km/h speed..
and your in stock tire also..
:Dgud luck sa mods bro..
Sir,
8That happened to me when i wasn't able to calibrate the Tachometer, it was on high act by default, you need to set it to low act for the MX frequency. so max RPM i have is close to 9K and topspeed ko stock is on my sig. but it is actually 128kph all stock now. Depends on how you breaked it in.
ESOJ de GUZMAN JR
sir its only in the max view.. and i choose hi-acct. my max rpm only 9k.. my tire circumference is 105% which is 70-90 front, 70-100 rear.. nothing change.. and the gps im using is nokia e72.. almost the same.i just strap it in my neck. it can reach 120kph when fully straight highway.. my break-in process was done by watching youtube and read the site www.mototuneusa.com/break_in_secrets.htm. big help for the new bie..
ESOJ de GUZMAN JR
sir francisco.. try lower tire circumference.. your tire circumference which is 120% i think its not properly calibrate.. 1st gear can reach 60kph if that is your tire circumference in 8k rpm.. hahahaha. try 105%.
mac kevin
haha, 15k in neutral.. ang laki ng letter "N" na green, sa akin naman nung binalik ko sa stock settings, 120kph nalang cia, my backride o wala aabot pa rin 120 on 15-40. matagal nga lang, d gaya ng Honda CRF 250 na mataas sa height ko hehe, ang 120 KPH parang 10 sec lang ata, tested ko na nung nakihiram ako sa friend kong miner dito sa ComVal, ang lakas talaga arangkada//..
i am at 110% tire circumference. Stock tire should be at 105% I adjusted it when installed a bigger tire in front using the instructions manual by getting new tire circumference . But GPS (phone app is 122KPH) before it was 118kph using tubed type tires and stock foot peg. I removed the tire tubes, used Racing Boy Footrest v4 and weight everything and was able to shave 5kilos, I weigh 145lbs and use a semi synthetic oil and was able to bump my topspeed by 4km/hr (ride position used is dragged type).
:D
febe gienel celebria
pls. read da features of uma racing digital speedometer.. it's already recorded so it is in neutral.. it's not accurate.. sniper can't reach 15k rpm.. :D
ianghol
it can reach 15k rpm:eek::eek: by proper tuning and balancing of every parts of the engine, this will be a big project:(:( if anyone is wanting 15k rpm..the only big down to this is the great factor of wear and tear..:):):D:D
