TWO WHEELS MOTOHAUS PAINT and Modification Job
wingman44
skuter said:
boss, pwde post ka pic ng rearset na walang angkasan sa shifter side? yung sakin kasi, naipit yung rubber ng chain... naipit sya sa rearset, ang ingay eh... ano kaya solution?
Racing Boy Version 4 Rear Set
Note: pictures above were borrowed from another poster
Installed RB Version 4 Rear set (shifter side):
Racing Boy Race Type Rear Set (installed shifter side)
To prevent your chain from dragging the rubber chain guide, make sure your chain is not slack or loose. Avoid using smaller sprockets as this will make your chain sit too low on its guide causing it to drag.
This is very dangerous as this could cause the chain to hit the crankcase which could potentially lead to disastrous results.
I've seen this happened before.
You can also use a RB Auto Chain Tensioner as this prevents your chain from being slack much too often.
skuter
@ wingman
thanks po...
what i mean is yung rubber na naka gapos sa swing arm... diba kapag ver4 ang kinabit, naiipit sya? tapos tumutunog na squeek...hehehe
wingman44
skuter said:
@ wingman
thanks po...
Hindi ko naman na-encounter yang ganyang problema ng magkabit ako ng RB V4 rear set.
Baka pwedeng maiwasan by using spacer?
skuter
wingman44 said:
skuter said:
@ wingman
thanks po...
pinutol ko nalang paps.... hehehe ok na... pero d ko pa na try long ride...hehehe thanks :D
wingman44
skuter said:
wingman44 said:
skuter said:
@ wingman
thanks po...
You're welcome, tol
Mizpeh
Sir bukas ba kayo sa 31? Uwi kasi ako Pacita baka wala ako gawin nag-iisip akong gumala at dumalaw, pwede ba dumalaw sa inyo?
red_is_karma
sir wingman, pwede po ba malaman kung anong brand po ng platinum na spark plug ang pwede sa stock na sniper? gsto ko po sana magpalit eh, pang daily use po sana, ung di madali masira..
dave_ryan08
sir wingman magkano po magpababa sa front? may pinapalitan po ba dun? pa pm nmn po skin ang price thx po and ride safe newbie lng me
wingman44
Sorry tol ngayon lang uli ako nakapg-on line.
Pasensya na uli, tol
wingman44
Sorry tol pero hindi ako familiar sa platinum spark plug kaya hindi ako makapag-advice,
NGK Iridium spark plug kasi ang palagi kong gamit.
wingman44
300 pesos lang ang charge sa pag-lower ng front end ng sniper at walang pinapalitan dito.
Thanks, tol
wingman44
the_one said:
paps salamat s pagkabit ng fe s tropa yesterday..
HAPPY NEW YEAR TO TWO WHEELS..
Ako dapat ang magpasalamat sa iyo sa endorsement mo sa amin.
Maraming salamat, tol
wingman44
I APOLOGIZE FOR THE LATE REPLIES.
I was out of commission since Dec. 27 ( health reason).
Will be back to full circulation by next week.
Thanks for bearing with us.
Happy New Year to all !!!!
paliLIPArin
happynew year to all SOS lalong lalo na sau... balik nko bukas sa Cebu... naipit e masyado ng mga unexpected schedules...
Mizpeh
Maraming salamat sir, may utang pa ako sa iyo, hindi mo tinanggap. Bawi po ako sa inyo next time sir.
Maraming salamat ulit. Ayos pala yung gawa sir OK na OK.
