Uma 62mm Bore Squish Band / Shaving
Hi guys
just want to share this info
UMA Racing 62mm bore kit
- Piston top surface to block top surface clearance (no base gasket installed) = 0.53mm
- base gasket thickness = 0.5mm
- head gasket thickness =0.3mm
Using a digital meter
Piston top to block surface clearance without base gasket installed
After squishband/shaving, this is the new piston top to block top clearance
Hope that helps :D
rich_havens
I think its the late model of honda civic or hunchback.. In my 62 hi comp i just add another oem fan because when im in a traffic my temp goes up to 90-95 on koso meter, soon planning for an oil cooler of raider
y used oil cooler from raider if there is availble oil cooler designed for our sniper classic and mx...
@kr.r_sniper had this on his bike (oil cooler)
