Uma Digital Meter
marlocks
paps tanong ko po sana san nyo tinap ung red wire or 12v ? normal lang din ba pag nka off ang ignition switch ma rereset ang clock ?
ESOJ de GUZMAN JR
sa may ignition po.. saka lng marereset ung oras pag inalis ung battery or nabusted ung fuse. mali ung connection nyo po kng mareset ung oras pag pinatay ang motor.
  • Like
Reactions: Gie
marlocks
anung kulay ng wire sir sa my ignition ?
nka bili din ako ng koso para sa classic ko merun xa padala na socket na plug and play lang...
Gie
@marlocks kung wala na connector kasama sa koso nyo sir sa "Red" wire ng ignition nyo po dapat itap yung positive (red) wire ng koso.. pag sa brown wire ng ignition nyo kasi tinap yung koso marereset parin yung time ng speedo nyo kasi po walang standby voltage ang brown wire, magkakaroon lang po ng voltage yung brown kapag sinwitch nyo yung ignition key di tulad ng "red" wire always po may 12v yun..
Gie
kung wala na connector kasama sa koso nyo sir sa "Red" wire nyo po dapat itap yung positive (red) wire ng koso.. pag sa brown wire ng ignition nyo kasi tinap yung koso marereset parin yung time ng speedo nyo kasi po walang standby voltage ang brown wire, magkakaroon lang po ng voltage yung brown kapag sinwitch nyo yung ignition key di tulad ng "red" wire always po may 12v yun..
ooops! my apology for not speaking in english..;)
izmer
How to set time for uma racing digital meter?it back to original value when off engine.anyone know?
gunkhean
maybe is ur alarm... if u do not have an alarm system, please check the battery life. or u make a hidden switch to cut off the supply, that's why this happen to ur bike. just my 2 cent
izmer
Wha
What do u mean by hidden switch?example?
gunkhean
Wha
some ppl like to add extra kill switch, normally this kill switch will install between the key switch wiring, so when they park the bike, they will also on the kill swith, so the supply willl totally cut from the supply.
ESOJ de GUZMAN JR
Long press the left and right button for 5secs. The menu appear. Just keep on click the left button. On the 4th menu its the meter time. When you adjust just click the right button. When u got the correct time just click the left button. Just keep on pressing until the background return to normal.
JustinStock
this is my uma digital meter. the only thing you can reset is the trip A, trip B, top speed record, oil mileage but the odo cannot reset. when reseting just hold the ADJUST button. the right side for 3secs. if you like to adjust the rpm gauge, time, tire circumference, oil mileage. just hold the SELECT and ADJUST button at the same time. it will appear the RPM adjustment.
menu 1. RPM,
menu 2. lo account - hi account,
menu 3. tire circumference,
menu 4. oil maintenance,
menu 5. time
menu 6. backlight
Sir Good day can you please? help me how to get the number 5 menu? many thanks in advance Godspeed
ESOJ de GUZMAN JR
Long press at the same time the option and adjust button. The rpm menu appears. Just keep pressing the left side the option button until you reach the time. Thats the 5th menu.
JustinStock
Yes sir thank you very much. But now i have another problem. My smx now in 62mm bore up. It is very hard starting now i need to you both electric and kick start at the same time to be able to start the bike and the uma digital meter everytime i push the start button, the digital meter continue on and off and giving me false reading. do i need to buy high capacity battery or any suggestion sir please? also using uma racing cdi wonder if it has a relation in too much consumption of battery charge. thank you very much in advance Sir. Godspeed.
tabi1
The UMA digital meter sucks up some juice and is not very accurate I think with the volt readings. I manually shut down headlights and other electrics via a switch when I park it as I was having the same issue.
JustinStock
Sir tabi1 good day, do you have any remedy with our problem? can you share please?
tabi1
Just ensure nothimg is left on. We added a separate switch for headlights, as stock they stayed on as soon as you started the engine. I also have leds around the headlights and some other lights each on separate swiches. once this was done all has been fine.
JustinStock
Ok Sir tabi1 many many thanks. Godspeed ridesafe.
ESOJ de GUZMAN JR
due to automatic lights on when engine start. i prefer to buy the 2012 mx model. but i think a switch can be bought at the market with same with the old model.
JapSpeed
bro okay lng ba png raider 150 battery gamitin sa sniper natin? di ba to nkaka apekto sa uma digi meter?
