Uma Racing Cdi Imc (intelligent Map Control)
This is UMA racing cdi Intelligent Map Control
its a cdi with 4 mappings which you can choose
Map 1 is for standard bike
Map 2 is for stage 2 bike
Map 3 is for stage 3 modified bike
Map 4 is for heavy modified race engine
in each map, you can advance or retard its setting by +9degrees and -9degrees
depending on your requirements.
You can also set its maximum RPM you want your engine to attain.
from 9000 rpm to 15000 rpm at an increment of 100 rpm
hood jlw
Hi sir,i want to ask you something.this cdi we just select the number right?exp im select numbr 2,did i still need to adjust the dgree advance or retart?
depends on your requirements, you really have to know what you are doing when you set the advance or retard timing
nice.. does it peform better than brt or rextor sir?
if you are a tuner, this is better than rextor or brt due to you can adjust the settings.
TPS recognition?
does it have a built-in regulator?
it doesnt have TPS recognition, only rextor have TPS recognition
How much is it? Where can we get one? Ty and more power...
its available in most racingboy uma store dealers
hood jlw
Thanks for the answer sir..but im still cnfuse about retard n advance..how we want to know the setting need advanance or retard?sorry sir,i dont have any experiance
Roy_LC5S
thanks for your reply @traxxas-modifier, i had bought it and install to my bike. just wanna share an info.. during start up, it will not show the warning light. this has been confirmed by uma racing official fb page.
ross42102
Share us to more info sir regarding this CDI specially regarding if its still work well at low voltage rating or it has voltage regulator...=)
Roy_LC5S
based on my findings after just 2 days of used, i can't say very much. but it works well on my bike which gives the output of 12.5v the lowest (my previous brt cdi gives 13.4v) and 15.2v the highest. (with a constant average of 15.0v +-2.0v during ride). so, you know it. :)
ross42102
So in short sir, this UMA is much better than BRT regarding this voltage output or the other way around ??...
Sorry for having to much question with you..:oops: Coz I like this UMA specially its future that you can set the desired RPM you want BUT, i just need some info bout this CDI since this is new to the market and theres no forum or topic of discussion at this moment regarding this compared to BRT and Rextor...Hope your shared of experience and info will help others also to have an idea regarding this RCDI if they are planning to have this also....Thanks....:thumbsup:
