leatherback
go go for uma super head
Kay @kr_sniperkng sino man ang nkakaalam ng contact ni speed maniac please pk share nmn skin kc bibili ako ng UMA SUPER HEAD,thanks all.
sport=23/20can someone on the group tell the diff of pro at sport? may nakagamit na ba parehas? does the PRO already out on the market today? update please
this is for future mods![]()
thanks papa @ianghol but in case this two product will avail on market,, which of the two is advisable for daily sometimes racing use?pro=23/20
sport=25/23(not sure)
valves size is the main diff between pro and sport..
head design maybe same(sport head is not yet in the market)
hope this help![]()
i think its another way around, PRO has bigger valves than SPORT.. SPORT is now available in the market, the one used by sir Admin trax, so far PRO availability is not yet confirmedpro=23/20
hope this help![]()
out in the market na ung SPORT pap'swow!!!!! unang paglabas nyan papalagay na agad ako sana abutin ko hehehehe
yung PRO pa lang ang hindi pa
both heads can be use daily depending on the set up you have done and as long as you have lots of money for the gasthanks papa @ianghol but in case this two product will avail on market,, which of the two is advisable for daily sometimes racing use?
ahh..sorry bro.."nabaliktad ko"..i think its another way around, PRO has bigger valves than SPORT.. SPORT is now available in the market, the one used by sir Admin trax, so far PRO availability is not yet confirmed
thanks for the advice broboth heads can be use daily depending on the set up you have done and as long as you have lots of money for the gas
this heads are truly design for racing purposes![]()
I guess I'll stick on my current project and leave this HEAD for the meantime
since masyado pa sya mahal sa marketPrice today is not changing.can someone confirm if the price of this today is 15k? as I checked on the other site it is 18500 php..
because if it is 15k on our market today.. then it is cheaper instead of buying piece by piece on the other parts
Yes, curious too,,, hope its like 35HP,,,,,,,,,,,,,,,,,,,,,,,,,, if so I am all inany development on UMA PRO mga fafas....
