nothing yet sir..my block is still on break-in..up to 80kph only for now..on 3rd gear..what is your top speed papz changing ur carb into 28mm???
it is not advisable to used our stock pipe for the Vixion block,will the engine be ok if vixion block kit on a stock pipe.?
never mind not exhausting its full potential power...
will it be safe????
no idea sir..ive never tried it yet....i just want to know how would the engine responds...i know stock pipes are for stock units..
what i wanted to know is how would the engine reacts..
pafs rho what cams and valve springs are you using right now? and how many kilometers does it need to make waswas mode
using vixion kit on a stock pipe won't give you the full potential of the kit..its better to use an aftermarket pipe...i just want to know how would the engine responds...i know stock pipes are for stock units..
given this circumstances, it's ok with me..i know i would still have a boost after all.using vixion kit on a stock pipe won't give you the full potential of the kit..its better to use an aftermarket pipe...
IMHO, I know that will be safegiven this circumstances, it's ok with me..i know i would still have a boost after all.
what i am after of is "would this set-up just fine with the engine"..or..simply "is it safe?"
why Vixion Kit is OEM of yamaha and it is Diasil as well same with our stock bore, and its only 57mm.
it will give you some boost on your bike but not 100%.
never heard vixion kit exploded or what using a stock pipe...
*just correct me guys if im wrong.
noted po..jiGGer
its ok to use stock pipe on vixion tried and tested with my bike during the break-in period and no harmful effect happen but if you want to use the stock pipe everyday and no plan for pipe/muffler upgrage you can modify the elbow make it bigger than the stock
sorry but what is "smurfs"?
hope i can buy the kit asap.then another budget for pipe and others.
