VALVE and RACING cam
killerdeath
hi guys would like to know if any.one have tried changing to racing valve spring and racing cam with racing cdi.NO other mods except that.Want to know whats the performance will be,as my mech advice me to change the block,piston and carb 1st before doing the valve spring and cam.as there is not enough compression if i do the valve spring and cam 1st.so whats your opinion?
ohya is there any good brand reed valve?
hi bro
i change the ff
Valve Spring and Racing CDI
results is good performance, increase in speed
and increase in maximum rpm.
changing valve spring dont need to change carb, block, piston.
change of aftermarket cdi will remove your cdi rev limiter
change of valve spring will increase your rpm from stock 9200rpm to above 10500rpm
valve spring and aftermarket cdi works fine with stock blocks, stock carbs.
based from experienced.
killerdeath
guys i have problem after changing the racing cdi,valve spring,original yamaha clutch plate and racing clutch spring..
my bike is no more smooth.and my 4th gear has no power.PLZ help....hate the performance of my bike due to the power which is not delivered when i need.keep stucking.hope you guys understand what im trying to explain.
haen
@deathkiller : replace the racing cdi with stock first.. if all goes normal.. then ur racing CDi timing is not suitable to ur engine needs.. time for programmable CDI ... :)
EDIT : what is the racing CDI type.. is it adjustable ?
sigung
killerdeath said:
guys i have problem after changing the racing cdi,valve spring,clutch plate and racing clutch spring..
Care to give out what has been done to your engine more?? 4th gear has no speed increment? Sprockets maybe??? It is well known that these 135 4th gear ratio is too tall......... :wink:
Valve springs?? Is it a trusted aftermarket brand??? Stiffer isnt always better. As for me racing valve spring is a must only if you intend to rev your machine more than 11000 rpm
Why change of clutch system?? Running a full modified engine??You running drag machine?? Changing to racing types doesnt guarantee top speed performance.
Race cam+race valve spring+race cdi is a good top speed setup if you know how to properly tune it.
Anyway just my 2cents opinion........
great info bro...my opinion ,of we mod here n there,our bike also need a good clutch system too..i dont know the word is...erm..sory..hehehehhe
sigung
When running a full modified engine, a good clutch system does help. Here in Malaysia its hard to find quality aftermarket(racing) types of clutch parts. As for me running original clutch pads and a stiffer spring is enough though, no need clutch pads :wink:
killerdeath
the bike feeling is only can type in malay.sekat2 or bobok when i try to move off.Wats the problem.my intention changing this stuff so i can ride at expressway at more comfortable speed.Thats the reason i dont want to upgrade block,piston and carb.no intention for racing.just need smoother bike and abit more power.ohya my mech did change the pinjet to 22.5
I just suspect tt the pin is the 1 causing the bobok feeling
sigung
Go to your mechanic and ask him to reset the carb. Check your sprk plug, cam timing.
Try change to your original cdi back and test again.
malay guys
what is bobok?
@king
theres a reed valve in T135
its the AIS, look at the top of your cylinder head
where theres a small hose. inside it is the reedvalve.
plz do respect people on other country...bobok means like...didnt smooth..i think it is..
if u running on a stock pipe..it dont much help if u increase the pilot jet..mine had experiment it myself..i reset the pilot to stock..#20.0
if u increase it..the 1st to 2nd gear is much not smooth as before..coz the fuel entering the block is greater than stock...am i right???correct if im wrong..peace..
