lebih elok adjust kalo nak lg sedap..barongan said:minta tolong boleh ke kalau dah masuk cam racing tp tak adjust valve clearence,akan menimbulkan kesan eg ke nnt
Klau nak set tappet tu kena buka blk head tu..skru dah le byk lc kite nih..awak confirm ke pomen tu x set?sepatutnya dia kena set biar ngam dgn piston tu klau x nanti valve tu hentam piston tu nanti,xpasal2 kena tukar piston lg..klau xde knocking untung la awak..tapi klau de,awak kena jaga2 la..barongan said:minta tolong boleh ke kalau dah masuk cam racing tp tak adjust valve clearence,akan menimbulkan kesan eg ke nnt
mmg payah.... ex5 je senang nak ejas.... xyah bukak mcm2.....nizam88 said:setting valve nih mmng payah ar..
nak la.... kite set xdpat2 lg ni.... lg lg pilot jet....nizam88 said:aiyak...
malu nih nk cakap.. hahaha
kips aku tu slide petak.. local punya lor.. pakai pilot jet uma racing > <"
nak tau gak ke? carb local susah setting...
Pilot jet besar sgt tu bro..ble gear 4 awak bwk dlm 40kmh pastu full throtle mesti semput kan?dinn977 said:nak la.... kite set xdpat2 lg ni.... lg lg pilot jet....nizam88 said:aiyak...
kjap ok, kjap ko,kjap ok, kjap ko . . . . .
FC da dkat 2x ganda ni dr std......
moto x laju gak..![]()
skrg mj 100 - pilot 48
pkai pe28 je....
ps: tkut tengok saiz spoket tuh.....
kalo dkt hujung2 fullthrottle lak, dia jd semput2 naper ye? MJ tak cukup saiz ke?kamen rider x said:Pilot jet besar sgt tu bro..ble gear 4 awak bwk dlm 40kmh pastu full throtle mesti semput kan?dinn977 said:nak la.... kite set xdpat2 lg ni.... lg lg pilot jet....nizam88 said:aiyak...
pkai pe28 je....
Klau main jet 100,awak mula dr pilot 35..rembat gear 1 spy 3,pastu tgk plug klau perang tu dah ok la..klau hitam belegam tu myk lbh tu sbb semput2 bila tiba2 full throtle..
---mmg tgk dia buka spring ori pastu masuk spring racing tapi tak nampak pun cam ade adjust ape tp setakat ni ok gak bunyi tu mmg ade kwn kata bunyi pistong ring sbb pakai blok besar...kamen rider x said:Klau nak set tappet tu kena buka blk head tu..skru dah le byk lc kite nih..awak confirm ke pomen tu x set?sepatutnya dia kena set biar ngam dgn piston tu klau x nanti valve tu hentam piston tu nanti,xpasal2 kena tukar piston lg..klau xde knocking untung la awak..tapi klau de,awak kena jaga2 la..barongan said:minta tolong boleh ke kalau dah masuk cam racing tp tak adjust valve clearence,akan menimbulkan kesan eg ke nnt
try saiz nie de mj=110@115 ..pj 38,40,42 jarum takok tengah yerdinn977 said:nak la.... kite set xdpat2 lg ni.... lg lg pilot jet....nizam88 said:aiyak...
pkai pe28 je....
ok bang.... TERIMA KASIH ERK....kid said:try saiz nie de mj=110@115 ..pj 38,40,42 jarum takok tengah yer
lps tu apa jadi?? ok ke tak ok?nizam88 said:@lordlimmi
aku pun kene gak mcam hari tu, tapi disebabkan p.jet mahal nk beli, aku setting takuk kat jarum tu.. bnyak kali la gak test..
tgkuk uma racing ada. just PnP tok kabereta besar...nizam88 said:@dinn977
kau pakai tengkuk ape nk masukkan carb kips tu?
p/s spoket pun takut.. blom tgk lagi, lagi kecik dari aku.. aku tgk pun cam was2 je nk ajak main lap.. hahaha
cut off kot... cdi ape skrg ?lordlimmi said:kalo dkt hujung2 fullthrottle lak, dia jd semput2 naper ye? MJ tak cukup saiz ke?
aik....:shock:barongan said:---mmg tgk dia buka spring ori pastu masuk spring racing tapi tak nampak pun cam ade adjust ape tp setakat ni ok gak bunyi tu mmg ade kwn kata bunyi pistong ring sbb pakai blok besar...
barongan said:aslmkum bro kid ......selain tukar cdi kalau nak kuatkan api camna ye ade jln lain ke
