Vixion Block & Hi Speed 57mm Piston
jumz666
I have seen a 57mm dome piston made by hi speed.. i also know someone selling a vixion block w/ out a piston kit.Is it possible to combine these two parts.. i believe it will produce more power due to higher compression. any views on this?
docgabby
DEFINITELY!!!
SECOND PISTON FROM THE RIGHT..
docgabby
my old (yet new) set up (i used this only for 1k kms before i converted to my 210cc daily driver). my stock block with hispeed 54.05mm hicompression piston. i did a little honing for it to fit. this matched to stock valves. i used a 5.5 hispeed cams for this.
docgabby
this is what i use now.. 63.5mm bore kit using a cbr piston, i had to use a plus 9mm mio conrod (stock conrod of sniper is equal to plus 7mm mo conrod) in order to accomodate the 15mm piston pin, 22in/19ex big valve head, using stock raider valves (the stem is 3mm shorter than stock, i think then they didnt have stock length big valves available. this was made by hispeed. this is paired to a plus 3mm offset crankshaft. this set up is similar to what they used in a race in sepang malaysia years back and won. it proved to be reliable. the side of the block is built up to increase the volume of the coolant surrounding the bore. this is steel bore. the sleeve is sturdy because it is built in to the block and not "floating" in the middle like other designs. i have already logged more than 9k kms on this setup. i installed a big radiator with a bigger radiator fan for cooling. the water pump is mechanical (stock). i removed the valve near the thermostat so that coolant will flow continuously.
mj viloria
how much does it cost bro?the piston and what honing bro?..do you know where can i get it..and for how much?and does the hi speed cams necessary for this piston?sir?
