Vixion Kit Or A Balanced Crankshaft W/ Pin2 Or Tranny
mj viloria
my bike is on everyday use..and i usually involve it on drag race when someones brave enough to ask me for one.. :D
im plannning on my next mode on my bike..my friend suggest to have my crankshaft balanced with pin2..but some of my friend says go for the vixion kit..
**But I really Love my Stock bore and i think ill go for balanced crankshaft and buy some dome type piston for my stock bore or shaved my block?.:angel:
any insights masters?.
Suggestions please..your opinions are highly respected..tnx and more power T135 :coffee:
antibiotic404
Must better bro if you go on Vixion block it's plug and play less trouble and no need to dismantle the whole crankcase. specially if your using your bike on a daily routine. I'd tried already both set up on my bike and also bigger bore and bigger stroke. I beat lots bike bigger than the displacement of my bike on race track and street but it is not advisable to use it on race and daily use. believe me bro it's a pain in the pocket unless you you have a deep one.
mj viloria
sir why does it is not advisable for race and daily use?..what could be the problem when its used in daily and race?
antibiotic404
Bro in my case I enjoyed and always maximized the full speed potential of my bike current set Even on the race track and on the street. Which is bigger bore and stroke including bigvalve, Pan asean cams, sonic dome piston, ligthen balancer, CDI, 4th gear on the tranny, Ignition coil, balanced crankshaft at Precision Q.C. and many other set up. At first i enjoyed a lot the rush of speed and power. To include that xperienced a bend valve, a chipped piston, scratches on the block, a mixture of water/ coolant on the radiator and engine oil, the worst bend connecting rod that protrude on the crankcase creating a window ehehe. If that happened it will end up to frustration. I tell you bro if you are planning to go on race. you must provide another bike that you can use on a everyday use and the other one is for race use only so that you can juiced up the full potential of your race bike. On my end It is very expensive to serve both that purpose on a single bike It will cause you a headache.... Hope it will help bro.
mj viloria
what could have done that frustration on your bike bro?..it could be the balanced crankshaft?..
mitzie
same incident hear.
