what a question from scientist Sidro,..Sidro live in outer space,...Sidro said:Based on the manual, it must read about 14.1V to 14.9 and 14v is the normal charging voltage.
@TS: sir what meter did you used? Is it analog or digital? and what settings did you used? AC or DC?.
i usually get 14.7 or 14.8 volts reading but sometimes it will reach 15vSidro said:Based on the manual, it must read about 14.1V to 14.9 and 14v is the normal charging voltage.
aw ah. hehehe,, paps I think its ok if you read 15v, since on the manual indicates 14.1v to 14.9 volts?. a 0.1v difference and its not that complicated. And given that the meter you used is not calibrated. "nosebleed ako paps".thopiang said:i usually get 14.7 or 14.8 volts reading but sometimes it will reach 15vSidro said:Based on the manual, it must read about 14.1V to 14.9 and 14v is the normal charging voltage.
am using koso digital speedometer and i think its digital nhehehe
dont know if it is set to AC or DC
