Guys,
This is just a reminder to those of you who ar planning to upgrade to bigbore blocks with dome piston.
1) Up grade is easy and power increase is phenomenal.
2) Make sure that you install as many gasket as you can find between the block and crankcase if the kit comes with a dome piston to reduce compression and avoid detonation.
3) Detonation can be heard when you blip the throttle in idling and you listen for metallic knock.
4) During heavy acceleration you can hear metallic knock as if you valves has too much clearances.
5) Use fuel with higher octane rating of 95 plus.
The reason I'm posting this is because my piston was damaged due to detonation in which the symptoms are the above. Part of the piston between the two compression was broken off and scraped the liner.
Now I had to rebore it again (after running for only 560kms) but still don,t have the time. FYI
