lc-motospeed
haha, pardon me but i oso have no idea wats tat... fancy fancy names =P
yes that thing if u change it u produce more electricity and u can also achieve more rpm since is smaller than stock and can run in higher rpmgoff_d_p said:are you asking about the magneto or AKA "stator"? the charging unit for the electrical?
thats the part i mean but when u use them (from experience) u dont have light and its not possible to chanrge the batterygoff_d_p said:bro, it won't matter how big of a stator you use. it's not the stator that runs your bike. all the stator dose is charge your battery and run your lights when engine is on. thats it. all the other electronic parts like the (cdi) use battery power. if you want to have the power done like that, then yes you can upgrade your stator. but you also have to upgrade your rectifier, and all your electrical wiring on your bike, plus your battery will also have to be upgraded to a higher amp.
I know a company that will upgrade your stock stator (magneto) for $160 that Provides over 90 watts of DC power at idle. which would mean you would have to eather get another new stock stator, or take yours out. in which case you wouldn't be able to ride you bike.
and for a rectifier that will work with this increase of power is $80.00, 150 watt full wave regulator/rectifier for DC electrical systems. Wire connectors for use with all machines.
I can also get the battery's i think, but they will not be cheap and i'm not sure if they have the same size for our bikes
of course shipping is not included, and all parts are being imported from another country, so don't expect shipping to be cheap, and don't ask for a discount. because i can't get one for you, or me.
I also want to say, that with this upgrade, you can use HID with no problems, thats what these systems were designed for.
X Project said:You can't gain power by changing the stator, but lightening up your magneto and inertia sure helps... Or if you really want to go that far, you can remove the stator (total-loss). BTW, stator and magneto are two different things...
Haha. Been there mate. No point in my very honest 2 cents worth. Sounds fiercer though. Ha. The hassle of charging the batt everyday is very tiring. Benefit is engine response better.X Project said:You can't gain power by changing the stator, but lightening up your magneto and inertia sure helps... Or if you really want to go that far, you can remove the stator (total-loss). BTW, stator and magneto are two different things...
goff_d_p said:[quote="X Project":34r7w3ce]You can't gain power by changing the stator, but lightening up your magneto and inertia sure helps... Or if you really want to go that far, you can remove the stator (total-loss). BTW, stator and magneto are two different things...
Hi, I have stage 2 cam, with 300-320 degrees duration overlap... The cam lobes are both 1.5mm advance lift than the stock... Good for mid range to top end... No need for valve pocketing, just plug and play if your headset is still stock, custom made by Nan Ban... I am also selling my Nan Ban transmission because Im changing the gears suitable for bottom end to mid range circuit setting... The Nan Ban tranny is only the close ratio final gear of 1,2 & 4 not including the pinion/ shafting... Also anyone might be interested with Mio 300cc engine, no carb, pulley, clutch assy included only the crankcase, crankshaft, block, piston, cam, headset with bigvalves... The engine is dynamic balanced with counterweight on the crankshaft... This was purchased from Hi Speed Thailand directly and was tuned by HRC mech and Natong of FCCI... PM or sms me for the price... Thanks...CryptonX said:guys does any1 know a website that i can order online camsaft for t135?
or some1 can order one for me if its so plz state price in usd and if its possible pictures too or suggestions
