what is your engine oil??
rodds_16
what is the engine oil you are using now on your bike??compare it to your previous oil and why??difference and performance...thank you for sharing.
the_one
5100 4T 10W40
Specially developed for engines that require simultaneous lubrication with its transmission applications, 5100 ESTER 10W-40 maintains
stability and ensures less friction even at
extreme temperatures or under heavy loads.
With its extreme pressure additives, gear shifts
are enhanced. 5100 ESTER 10W-40 guarantees efficient wet clutch performance as well as gearbox longevity.
SPECIFICATIONS
Product 5100 4T 10W40
Feature Semi-synthetic, contains ester. Includes special additives that reinforces gears. Reduces noise and wear.
SAE/DOT Standard 10W40
Specification API SG, CCMC G5 & JASO MA
Maker's Approval —
Compatibility For 4-stroke engines with integrated gearboxes. For use in all conditions, roads, city and off-road.
3100 GOLD 4T
Oil for 4 stroke motorcycle engine
Technosynthese
Excellent ati-oxidation preventing premature oil thickening and ageing due to high temperature stress. High lubricating properties which decrease friction and wear and increase engine life.
SPECIFICATIONS
Product 3100 GOLD 4T
Feature Technosynthese
SAE/DOT Standard 10W-50
Specification API SL & JASO MA
Maker's Approval —
Compatibility All 4-stroke motorcycle engines –Road and off road bikes, Trails, Cross, Enduro….
Sidro
BasTarD said:
castrol power1 synthetic
liquid engineering :D
:lol: :lol: :lol: ,, ayos!!!!,, hahaha
sa akin, kpag walang time mag change, Yamalube sa 3's shop plus change oil(may coupon pa)
and if may time Castrol Racing gold. 382.50php. hehehe
BasTarD
yang johnsons baby oil...para sa "change oil" ko yan...15 pesos
ala mabili dito gensan eh, kaya nag istock ng marami para pang konsumo at negosyo :D
guys share more oil brands that you use.
kung out of budget ako i use this
the_one
PARA S MGA SERYOSONG KARERISTA!!!
300V 4T FACTORYLINE 5W30
"Double Ester Technology for Motorcycle Engine".
This technology made possible to spur on an optimum output by reducing the friction of the oil film while maintaining stable oil pressure.
On the other hand, the slippage of the clutch system is minimized by the increased friction between the clutch plates, this then enables the power output to be increased at the rear tire. Improved power output and more reliability at the same time.
5W30 is for race engines, qualifying engines designed to run a low viscosity oil, MX, speed bikes, street bikes, scooters etc.
SPECIFICATIONS
Product 300V 4T FACTORY LINE 5W30
Feature Double Ester, 100% Synthetic. For more power and reliability.
SAE/DOT Standard 5W30
Maker's Approval — Compatibility All 4-stroke motorcycle engines – Qualifying & Racing engines, Low viscosity, off-road rally, trails and street use.
rodds_16
ako naman he he..before i used shell advance VSX for my honda XRM pra sa akin mas smooth sya compare to others na naitry ko..for my sniper now wala pako naitry na satisfied ako i used once ung VSX at yamalube pero d smooth kya ako naghahanap ng mga suggestions kung ano maganda para stock engine ng sniper..thanks for sharing mga paps..
EinVer
before:
Yamalube - medyo ma vibrate, at masakit sungkitin ang kambyo sa katagalan (stock pegs)
Castrol Activ Premium - mas malambot ang pakiramdam sa pag shift ng gear, pero saglit lang change oil na ko agad (800kms)
Castrol Power 1 Semi-Synth - mas maganda konti ang performance, at mas matagal konti mag change oil (1200kms)
ngayon gamit ko, Repsol Moto 4T Rider 15w-50
mas smooth sa gear shift (sungkit sa stock pegs), less vibration sa high rev
change oil every 1000 to 1300 kms
after 3 change oil sa Repsol, try ko naman ELF moto, maganda daw sabi ng katropa ko....
