guys anyone have tried changing their valve spring?
what brand is the best?
bro can you sourced out?haen said:TK Racing .. then ASEAN Cup spec for the best...
how many washers did you add bro?justkir said:im using stock with additional washer....it seems the after market valve spring tends to expand when its hot... so i use back the oem and add in washer to harden it...
earch the thread title "sharing my head" for the feedback with that valve springsir, you have a picture of this valve spring that you mentioned? have you tried sun valve spring? sorry noob![]()
don't have picture of this because i already sold it when my Sniper got total wreck, sun is not good better to use hispeed then add a 4mm washer as a basesir, you have a picture of this valve spring that you mentioned? have you tried sun valve spring? sorry noob![]()
i dont want that darn thing be installed on my engine. that was nasty. is it due to soft valve spring installed? wheew! sir how about mtrt?
better use the hi speed than mtrt, it's not recommended for hi lift camswoooh!i dont want that darn thing be installed on my engine. that was nasty. is it due to soft valve spring installed? wheew! sir how about mtrt?
im planning to install a stg 1 lhk cam. how about faito valve spring?do i still need to add a 4mm washer?better use the hi speed than mtrt, it's not recommended for hi lift cams
