what went wrong?
Undah-Bone
to all my T135 brother's i need your help and advice. how could it be possible for my engine to be seriously damage this way? here is some pictures.
got a broken valve, piston, block, connecting rod.
any idea on why does it happen to my engine? and what damage parts on my engine do i have to replace?
haen
something got into the combustion chamber i think.. that's assuming u didn't mod anything to ur engine.. maybe someone do something.. like putting iron ball into the manifold ?
wvlfonlus
A. overrev?
B. Jet Fuel?
C. Ball bearing inside the engine?
D. Grinnding compound inside the engine?
E All of the above?
:idea:
marvymavs
Naka aggressive cam ka ba sir undah? If oo, nung nagoverrev ka, tendency is valve float unles you are not using stiffer valve springs. Just a conclusion:
Nagoverrev ka, nag valve float, dahil nagvalve float, hindi lumalapat yung valve lip sa valve seat, inshort, tumukod yung partially opened valve sa compression stroke ng piston mo (TDC) causing the piston to hit the valve then nabali at yung putol na ulo ng valve ang nagcause ng pits sa piston crown mo.
Kaya sa mga gumagamit ng hi-lift na cams, make sure nasa preffered measurement ang valve clearance nyo ang use stiffer valve springs.
raider125jeigh
huhuhu.... i feel you papa undah...
first problem was water was mixing in to your oil.. then you said it was fix...
much better if you can provide information about the history of it before it happened
hearthrob16
WTF! look at those piston rings you fried! and the head! lesson learned! next time bring your bike to an engine scientist.. :twisted:
raider125jeigh
hahahaha i thought you mean a. E.T hahaha
