Yamaha T135 Discussions (ENGLISH SPEAKING AREA) » General Topics » what went wrong?
oichearthrob16 said:EinsTein!!!raider125jeigh said:hahahaha i thought you mean a. E.T hahahahearthrob16 said:WTF! look at those piston rings you fried! and the head! lesson learned! next time bring your bike to an engine scientist.. :twisted:
much better if you replace your block with vixion block..at least it is genuine..and about the head assy,i am using a yamaha genuine big valve head..raider125jeigh said:oichearthrob16 said:EinsTein!!!raider125jeigh said:hahahaha i thought you mean a. E.T hahahahearthrob16 said:WTF! look at those piston rings you fried! and the head! lesson learned! next time bring your bike to an engine scientist.. :twisted:
albert the scientist einstien..
if any case i will have money ill go there as well.. but the engine of the TS was really damage...
i can suggest to rebore the block and purchase vixion piston that cost 5.5k
oicat said:there you again idoitic pekz!!!! nothin to do with cams!
problem valve tapet or cleance was too loose... your over rev exhaust valve broke
went inside the piston blocked the compression thats why you rod got busted too! no need for valve pocket...
good thing i checked mine yesterday or that could happen to me as well because my valve seal wasnt the right one so had to change it
look at ur head gasket too much tribond which i had too...
too much open pipe does as well that no return pressure thats what my mech told me prone to valve float..
