whats the best pipe for stock engine?
Sidro
i've mentioned the distance travelled it took for the bike to attain the said speed..i hope if you can comment longgggggg enough for this,you can also read longgggg enough for the posts..that was according to his bike's speedometer,and i think it's ok because last december we had this night ride and i was running 130 and he's tailing me and getting close..so i can say is that DBS pipe is really good for stock engines..maybe racing boy swing arm,modified fairings to 1 seater and swallow tires can add to the speed?hahahahaah
youre soooooo cooooolllleeeetttt.. hehehehe
AJM
the best for stock is anything that you want but remember that the pipe should be as small as the stock one
Ritzsoulfly
stock engine,faito clutch spring,cms valve spring, racing cdi,42-15 sprocket combi,100/80 r 80/80 f tire,28mm carb, 4N pipe+Prayer=140kph 1km run....from magallanes to nichols.....^^
