proper carb tuningmga masters,may tanong lang ako AC sniper motmot ko,ang problema ko ay ganito, while driving at nsa 4th gear na,pag magmemenor ako,pra bang may pipigil at prang nka engine brake,pag ipipiga ko nman di ko mapi-feel ung ganon.ano kaya cause nto?tia masters
sample paps, first gear,second,third and fourth, smooth ang takbo,pru pag mag menor ako,dun na medyo may pipigil or like nka engine brake ka sa first gear (given na nka 4th gear ka).di talaga xa normal,wla kasing ganito nung una eh.What do you mean i think when you release the throttle is normal to have an engine brake ..
sana nga paps.thnxproper carb tuning
ung parang naiipit pag nag engine break ka pafs?sana nga paps.thnx
are you using racing carb sir? what is your jets?Kung baga ung takbo ng motor is like flowing water,smooth tas bigla nlang may babara/bumabara sa daloy,pru pag aarangkada ka ma wawala nman.ma fifeel lang ung abnormality kpag steady lang hwak mo sa throttle.
Jetting?Kung baga ung takbo ng motor is like flowing water,smooth tas bigla nlang may babara/bumabara sa daloy,pru pag aarangkada ka ma wawala nman.ma fifeel lang ung abnormality kpag steady lang hwak mo sa throttle.
try mo pong bugahan ng compressor yung jettings mo sir...baka my nabara sa loob...wala naman pong mawawala kung itatry naten..yung sa tropa ko kasi date ok yung low rpm kapag biniga nah niya biglang mabubulunan nah ehwan yung motor, yun pala nagbara nah yung jettings...try mo lang sir...malay naten...already tuned up my MC, but still the mechanic did not get to the bottom of my problem,he suggested that I rather convert my AC to HC,bcoz the clutch pressure plate is already thin...I will try other mechanic this weekend, if they have the same findings,then I'll follow it.
. If your clutch lining is thin, it would be the opposite (engine revving but lesser pickup).parang mali yung suggestion nang mekaniko mo baka gusto lang nyan kumita di naman siguro aabot sa ganyan kailangan na ba agad convert mo Mc mo Ac to Hc, I`m sure di yun ang sulusyon, kung manipis na clutch pressure plate mo need na siguro palitan, tama din mga sinabi nila baka barado na jetting mo, carb proper tunning, or baka naka choke ka! ! ! ! ... try mo din yun bro! ! ! .... sana makatulong ...already tuned up my MC, but still the mechanic did not get to the bottom of my problem,he suggested that I rather convert my AC to HC,bcoz the clutch pressure plate is already thin...I will try other mechanic this weekend, if they have the same findings,then I'll follow it.
