try change to silkolene pro 4medichloreans said:mine 8k km...
been riding since july 2006
170km/h (t135 msian version speedo isn't accurate)
stock tire..
stock cdi..
silkolene comp 4 (every 2250km)
change oil filter on 1st n 2nd service.. after that change every 4500km...
clean the sparkplug every 1k km.. change it every 5k km,
standard sparkplug ngk cpr8ea9
coolant not yet.. will change it annually or 12k km whenever came first..
maybe i'll using yamacool coolant or motul inugel...
will change air filter annually.. still can use.. not worn/dirt enough..
rooster..
did u check your air filter??
stock tire..
stock cdi..
rooster..
i already use denso iridium rm55. model U24.medichloreans said:im using silkolene comp 4
pro 4 is to expensive for me...
denso iridium still not produce iridium for 135lc..
ngk also still not produce platinum/iridium...
Yupjustkir said:tsunami, u using silkolene pro 4 plus, 15w-50w is it?
Lor KL is big town why you cant find any of denso iridium spark plug there.medichloreans said:kuala lumpur...
u r using iridium olug??
phew..
i want to use platinum plug but ngk still didnt produce 4 t135 yet..
even iridium plug that u currently using not specially made 4 t135...
