Go for the racing CDI. Racing coil will only give a little power compared to the installation of rCDI. Your next project should be the racing ignition coil.i had bought a Namban Racing Coil and the mechanic told me about the installation of a racing coil, the wire should be cut to shorten it and connect a spark plug booster to make it more powerful....infact my Namban racing has a long wire attached. Is it ok to do that? My Snipee has already a spark plug booster.......
He also knew that am going to buy a BRT DualBand Racing CDI and he insisted me that if i will buy a racing cdi, no need a racing coil for that. I'm now confused on his idea.
Help me masters which is good for my snipee.....my plan is to buy those both BRT DualBand RCDI and Namban Racing Coil.
Salam Bro,Bismillah.
BRT Dual band Racing CDI no need a racing coil. The manual book of BRT Dual band Racing CDI says the stock ignition coil should not be replaced by a racing coil. I have tried it on my Jupiter MX.
There are 3 kind of BRT rdual band Racing CDI.
1. Standard/Tune-Up or S/T
2. Tune-Up/Racing or R/T
3. Tune-Up/Kompetisi or T/K. "Competition" in indonesian is "kompetisi".
Each type of these CDI is depend on the modification of our engine.
Bismillah.Guys, is it ok that am goin to install BRT DualBand RCDI, Racing Ignition Coil, Spark Plug Booster, DBS Pipe, Sprocket Combi 14/42, Tire 80/80F 90/90R but my engine is stock? Just for city riding and long distance ride.
It's okay but with 14/42 sprocket combination you will loose your top speed. You will gain acceleration though. Be careful with the rCDI specially you are using stock valve springs. Learn to lower your throttle when you are already on high RPM.Guys, is it ok that am goin to install BRT DualBand RCDI, Racing Ignition Coil, Spark Plug Booster, DBS Pipe, Sprocket Combi 14/42, Tire 80/80F 90/90R but my engine is stock? Just for city riding and long distance ride.
By using rCDI, the valve spring should be aftermarket/racing spring valve? What should i change when using rCDI without reboring my enginge?It's okay but with 14/42 sprocket combination you will loose your top speed. You will gain acceleration though. Be careful with the rCDI specially you are using stock valve springs. Learn to lower your throttle when you are already on high RPM.
rCDI has no RPM limit and that's why you need stiffer valve springs . The valve spring you need is not necessarily be after market brands like Vixion valve spring. You just need a stiff valve spring to avoid valve float and it only happened that most of it came fron aftermarket products.By using rCDI, the valve spring should be aftermarket/racing spring valve? What should i change when using rCDI without reboring my enginge?![]()
